Results 1 to 4 of 4
Thread: Detergent not dissolving in washer
    Jul 2006
    Santa Clarita, CA
    Default Detergent not dissolving in washer
    I have a 5 year-old Maytag Jet II dishwasher. Lately I've been noticing that the powder detergent I'm using (either "Electrasol" or "Cascade Complete") is not dissolving thoroughly during the normal wash cycle - about 1/2 the powder remains in the cup(s) after the cycle is finished. Also, a small pool of water often remains in the washer after the cycle is complete. I can't find my Owner's Manual to try and troubleshoot the problem. What should I do?
    Is the detergent dispenser door opened fully when its done? Then you see half the detergent left over?
    Whats the model#?
    Sep 2006
    canada
    Default Same problem with detergent not releasing
    Hello,
    We have a similar problem with our mdb7100aww.
    The detergent door opens, but it does not get washed into the cycle.
    We've looked at the dishwasher, but are unsure of what could be the problem.
    Any advice is appreciated.
    Miles
    1. Check the water temperature. Should be 125 to 140 F.
    2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
    3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
    4. Check the spray arm and pump cover for splits or leaks.
    5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
    6. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
  1. Maytag mav7000aww Top loading washer loud clicking noise during spinning
    By alan509 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 23rd, 2007, 06:18 PM
  2. Detergent Door will not open! Need wiring diagram.
    By Bob Swerski in forum GE/Hotpoint
    Last Post: July 11th, 2006, 12:12 AM
  3. Elite not dissolving detergent tablet
    By d169stang in forum Sears Kenmore
    Last Post: May 3rd, 2006, 10:35 PM
  4. detergent isn't dissolving
    By staggerlee in forum Whirlpool/Roper/Estate
    Last Post: March 14th, 2006, 12:54 AM
  5. Kenmore washer intermittent burning smell
    By mvmartin in forum Sears Kenmore
    Last Post: February 10th, 2006, 01:40 AM
