Results 1 to 10 of 14
Thread: Maytag Performa Washer will not spin
    Jul 2006
    Pittsburgh, PA
    Question Maytag Performa Washer will not spin
    I have a 3 year old Maytag Performa Washer - Model PAV3360AWW. I have recently had problems with not all of the water draining from a cycle (had to put loads on an extra spin) and begining this afternoon, the washer will not spin. I have checked everything listed in the user manual and things seem to be in order. Any other suggestions?
    Jul 2006
    Pittsburgh, PA
    ... more information ... Based on information from other sites, I have checked and it does not seem to be agitating either. Any thoughts / suggestions would be appreciated.
    Apr 2006
    S. Central PA
    Check the belt if off///loose...
    Jul 2006
    Pittsburgh, PA
    Thank you. I will check it tonight.
    Jul 2006
    Pittsburgh, PA
    The Belt looks OK - was on correctly and tight. I guess it is something else. I will be calling a repairman tomorrow. Thanks for the advice.
    Jul 2006
    Tennessee
    Quote Originally Posted by jskaldorf
    You most likely need a thrust bearing kit #12002213. It consists of the big pulley under the unit and the bearings that help release the brake.
    Jun 2009
    San Antonio, TX
    Help!!!! My Maytag Performa Washer will not SPIN!!!!
    Model # PAV1000AWW
    Serial # 12773598UU
    I don't know what is causing this, but when it is on the spin cycle, my washer will stop spinning and puts out a burnt smell. When it stops spinning I think it's just because the clothes are throwing it out of balance, so I go and rearrange them and start it up again. However, when it starts it makes a loud buzzer sound like you hear from a dryer and it begins to spin again. Then after a few minutes it stops again and you smell that burnt smell. What could it be? I would appreciate any help.
    Respectfully,
    7gonzo7
    Possibly the motor, but you'll need to tilt the washer back, then take the belt off underneath, then try a spin cycle with no belt on, the motor should run alone, if it still does the same thing, you have a bad motor.
    Here's the motor for your model you can order:
    Motor: 21001400
    Jan 2011
    Virginia
    And if the motor does spin? then what might be the problem?
    Like I said in your thread you already started, under a load it can make the motor kick-off on overload, that would mean a bad motor as well.
  1. Maytag Dependable Care Washer Squeal/Sqweak on Spin Start
    By ggallant in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 9th, 2007, 01:43 PM
  2. maytag performa - washer spins, but clothes still too wet
    By lifetooshort in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 20th, 2007, 01:13 AM
  3. Replies: 5
    Last Post: November 26th, 2006, 10:37 PM
  4. Maytag Washer - Rapid Clicking During Spin Cycle/White Dust Under Transmission
    By rickalders in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 20th, 2006, 02:22 AM
  5. maytag performa - washer spins, but clothes still too wet
    By wahoo in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 11th, 2006, 01:42 PM
