Results 1 to 7 of 7
Thread: Whirlpool Gold water dispenser is leaking
    Aug 2006
    Ohio
    Default Whirlpool Gold water dispenser is leaking
    Help needed, my Whirlpool Gold side by side is leaking water from the water dispenser on the front door. It is model number GS5SHGXLQ00, manufactured date of 03-02. Can anybody provide assistance? Is this something that I need to call a certified technician for? or is it something that can be fixed easily?
    Thanks in advance for any assistance.
    Is it a constant drip at all times? If so you will need a new inlet water valve.
    Here is the one for your model:
    Water inlet valve kit
    Aug 2006
    Ohio
    Thanks for replying. Yes, it is a constant drip. Is it easy to install the part you recommended or do I need a professional to do it?
    Aug 2006
    Ohio
    Also, what is the difference between parts #3307 & #949403?
    Yes, its fairly easy to replace, just pull your refrigerator out from the wall, then turn your water supply off, then unscrew the water line hook-up to that water inlet valve, then unmount that valve and remember/write down where your water tubing & electrical connections go, then just place them the same on the new valve.
    The 949403 is the upgraded water inlet valve from the 3307.
    Aug 2006
    Ohio
    Jake, thanks for all your help. I just ordered the part.
    Sounds good, keep us posted.
  1. Leaking Whirlpool water dispenser
    By mydogrufus in forum Whirlpool/Roper/Estate
    Last Post: March 30th, 2007, 10:07 PM
  2. Kenmore refrigerator water dispenser drips
    By Mike C in forum Sears Kenmore
    Last Post: February 6th, 2007, 09:57 PM
  3. Whirlpool Gold water drip from dispenser
    By wiznkids in forum Whirlpool/Roper/Estate
    Last Post: November 30th, 2006, 10:31 AM
  4. Whirlpool Gold GR2SH Leaky Dispenser
    By advicefa in forum Whirlpool/Roper/Estate
    Last Post: November 17th, 2006, 11:32 PM
  5. GE Profile water dispenser line leaking
    By dlynch in forum GE/Hotpoint
    Last Post: October 4th, 2006, 09:17 PM
