Results 1 to 9 of 9
Thread: GE Monogram
    Aug 2006
    Michigan
    Default GE Monogram
    We have a GE Monogram s/s and the fan motor in the freezer keeps icing up and then will not run. What would be causing this?
    Whats the model#?
    Aug 2006
    Michigan
    I do not know what the model # is, I cannot find it on the frig anywhere and cannot find the manual either.
    Aug 2006
    Michigan
    Talking
    This is a built in s/s with the condensor and fan on the top of the frig/freezer.
    Oh, so its a built-in model?
    Sorry, I don't have any repair experience on built-ins.
    Hopefully another tech. or member can help you out.
    Sep 2006
    Minneapolis, MN
    Default water from condenser on top
    sou nds like you have the same problem I have
    I have a ZISB42DYb s/s builtin monogram
    The ice comes from the top condesnor and drains into the freser, sometimes covering up the moters - it seems the drian gets cloged or does not work well
    I can not see how the drain tube goes from the bottom of the condeser unit to the bottom of th evaprator unit
    I suspect the bottom header is not keeping the watter flowing in the correct direction, to the rt to the evaporator
    Aug 2007
    Los Angeles
    I see this post is very old. Have you solved the problem and what was it that was done? I am starting to work on Mono's and am trying to collect whatever feedback I can get...
    Aug 2007
    NY
    Quote Originally Posted by reeferman View Post
    Most of the time, the problem in this thread is caused by a clogged condensate tube. It could also be caused by a failed condensate pan heater, condensation build up on the evap compartment ceiling etc... The fix is a GE icing kit part# WR49X10021. It is a difficult job. Unless you have done many of these, I suggest you pass on this job and refer the customer to GE factory service.
    Jan 2007
    San Diego CA
    VERY common problem on GE built ins, model # ZISB or ZISW
    Poor insulation of the upper evaporator box.
    Ive seen some with a heater installed but it didnt do a very good job.
    Econo Appliance Service - San Diego appliance repair experts!
  1. GE Monogram Fails to Cool
    By pbear in forum GE/Hotpoint
    Last Post: August 2nd, 2007, 06:13 PM
  2. GE Monogram no ice/low freezer cool
    By wbuster1 in forum GE/Hotpoint
    Last Post: March 29th, 2007, 08:29 PM
  3. Monogram Ventilation Hood ZV950SD
    By ng622 in forum Ranges/Ovens
    Last Post: December 5th, 2006, 11:23 AM
  4. GE Monogram drain plug issue
    By conviso in forum GE/Hotpoint
    Last Post: September 17th, 2006, 12:08 AM
  5. GE Monogram Water Reservoir Freezing
    By jldaddy in forum GE/Hotpoint
    Last Post: August 19th, 2006, 10:35 PM
