Results 1 to 4 of 4
Thread: Roper (Whirlpool) RAX4232KQ0 Washer Won't Drain or Rinse
    Sep 2006
    canada
    Default Roper (Whirlpool) RAX4232KQ0 Washer Won't Drain or Rinse
    My Roper RAX4232KQ0, Type: 107, fills with water, goes through the wash portion of the cycle, and then gets to the rinse portion and stops. It won't drain or spin in any of the 4 cycles and the water has to be syphoned out. I can hear (and see) the timer moving along until about halfway through the rinse portion, then it also stops completely. Any idea what may be the problem and how to fix it?
    Thanks.
    Oct 2004
    G'day,
    Ckeck the lid switch and/or lid switch probe. If the lid switch fails and spinning and draining will quit but the filling and agitation will still work...
    Lid switch assembly
    Access helps...
    http://www.applianceaid.com/procedures.html
    Appliance Repair Aid
    Sep 2006
    canada
    Yep, the assembly was broken where the screws attach the switch to the machine right under the lid. As you can probably tell, my mechanical aptitude is quite low!!! Thanks for the quick and easy diagnosis.
    Oct 2004
    Thankx for the update!...your welcome
  1. FIXED: Another Whirlpool Dishwasher won't drain
    By rickm in forum Whirlpool/Roper/Estate
    Last Post: January 26th, 2016, 04:46 PM
  2. Kenmore Elite Catalyst washer won't drain & spin
    By Brittgee in forum Sears Kenmore
    Last Post: July 26th, 2010, 09:05 PM
  3. Drain problem with my Whirlpool washer.
    By Romen3 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 5th, 2006, 01:09 AM
  4. Whirlpool Washer not Spinning
    By limetwist in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 17th, 2006, 05:30 PM
  5. whirlpool calypso washer won't drain
    By futurevip in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 12th, 2006, 02:08 PM
