Results 1 to 6 of 6
Thread: Kenmore Ice Dispenser Flap Door?
    Jul 2006
    Georgia
    Default Kenmore Ice Dispenser Flap Door?
    Hello,
    My Kenmore model # 25359683992 is having a little problem with the ice dispenser. The flap door does not open and prevents the ice from going through. It was working fine and just decided to stop working, granted it is almost 6 years old. Do I just need to replace the solenoid for the flap door? Is it possible that something else is broken? Everything else works, water, crushed ice, cubed ice. Thanks for your help in advance.
    Its likely your heat motor that opens and closes that ice dispenser door has gone bad.
    #35 here is your heat motor:
    http://www3.sears.com/imaging/ImageP...&titleID=00007
    Here is the new one for your model:
    Heat Motor
    Jul 2006
    Georgia
    Thanks for the reply Jake, I will go ahead and order that part. Is this easy to replace or can I do it myself? Thanks again for the help.
    Yes, it fairly easy to replace, just remove #23 & there is a screw under #28 to move then that comes off, then take the 2 screws off from your dispenser, you will see them after you remove #23. Then remove the 4 #26 screws, then get a putty knife and pry out the dispenser housing #4 on both sides, don't worry you won't break it, it has double sided tape on the back of it. Then you will see the heat motor on the right side.
    Make sure you unplug your refrigerator before making this repair.
    Jul 2006
    Georgia
    Thanks a lot for all the help Jake, I will install it once I get the part. Thanks again for the assistance.
    Glad to help Spyder, Let us know how it goes.
  1. Replies: 1
    Last Post: May 6th, 2007, 12:21 PM
  2. Kenmore Side by Send ice dispenser not working
    By jacklx1 in forum Sears Kenmore
    Last Post: December 27th, 2006, 11:44 PM
  3. ice dispenser flap
    By Paul Giguere in forum GE/Hotpoint
    Last Post: October 22nd, 2006, 02:00 AM
  4. Kenmore front door dispenser water drip
    By bnplu in forum Sears Kenmore
    Last Post: October 10th, 2006, 06:47 PM
  5. ice maker dispenser door closer
    By pmarcosa in forum Sears Kenmore
    Last Post: August 3rd, 2005, 11:26 PM
