Results 1 to 10 of 10
Thread: GE Water Dispenser Tube Clogged
    Oct 2006
    Greenville, SC
    Default GE Water Dispenser Tube Clogged
    I have a 3 year old GE SS refrig. The ice maker works fine, but the water dispenser isn't working. I disconnected the tube going into the freezer door, pressed the dispenser lever and no water flowed so I replaced the water valve in back. Now water flows to the freezer door connector, but not through to the dispenser.
    I thought maybe that ice had clogged the line so I used a hair dryer to try and melt it -- no luck. I tried shooting compressed air in the line, but no luck.
    Here is my question: Does the tube go straight to the spigot or is there something else there like another valve, another filter or a reservoir?
    If not, the tube must be clogged with something. Any ideas? How do I get access to it?
    Whats the model# of your refrigerator?
    Oct 2006
    Greenville, SC
    Default Model #
    The model number is GSS25SGPA SS
    No, you don't have an extra valve in your freezer door on your model.
    I would just keep drying the hair dryer, it make take awhile to defrost, but you will eventually get it.
    Oct 2006
    Greenville, SC
    Red face Bad to worse
    Thanks Jake,
    I applied the hair dryer directly to the spigot. Two bad things happened; 1) now the trip switch (dispenser switch lever) doesn't work - no water, no ice, no soleniod opening the valve sound, nothing. I must have overheated it. and 2) the hair dryer stopped. By the way, the tube is still clogged.
    I guess I should have taken the door apart and gone at the tube from the inside.
    How do I access the trip switch and the tube from the inside?
    Here is a part diagram of your freezer door assembly:
    http://www3.sears.com/imaging/ImageP...&titleID=00001
    #93 just snaps off, then you can access the switch.
    Oct 2006
    Greenville, SC
    Default Thanks -- I got it!!!
    When I got back in there, the switch was OK but the heat had soften and mis-shaped the plastic dispenser level so it wasn't tripping the switch. I reheated it and bent it back.
    Strangely enough, the water is now working as well. I guess the heat did melt through afterall.
    Even though everything is currently working, I think I'll go ahead and replace the plastic parts I had to bend back.
    Good idea.
    Glad the water is coming out good again.
    Feb 2008
    California
    Default GE Model GSH25SGRB SS; Ice but no water
    Would this thread apply to a GE Refrigerator model #GSH25SGRB SS. Ice maker IS working, however water dispenser in door is NOT. Thanks.
    Yes, but first check here and read in post#17 about what GE Jim says to do before anything else:
    http://www.applianceblog.com/mainfor...spenser&page=2
  1. Water Dispenser SDX26VL
    By jxp_app in forum Amana
    Last Post: February 8th, 2007, 11:49 AM
  2. Kenmore refrigerator water dispenser drips
    By Mike C in forum Sears Kenmore
    Last Post: February 6th, 2007, 09:57 PM
  3. Frigidaire SxS water dispenser is dripping water
    By batman in forum Frigidaire/Electrolux
    Last Post: June 13th, 2006, 12:15 PM
  4. Cracked plastic tube for water dispenser
    By DarthMaul in forum Sears Kenmore
    Last Post: June 7th, 2006, 10:06 PM
  5. Replies: 7
    Last Post: January 2nd, 2006, 10:22 AM
