Results 1 to 4 of 4
Thread: Kenmore 70 series stops after 10 minutes
    Jun 2006
    Pennsylvania
    Default Kenmore 70 series stops after 10 minutes
    Hi I have a kenmore dryer 70 series heavy duty electric dryer. The problem is the dryer will run for 10 minutes or so and then stop working. If I go and push the start button the dryer starts right up. I did read another post about the timer and it said if it buzzes in the off position its a bad timer(my dryer does that). Are there any other parts I should check? Does the thermostat shunt the circuit somehow? Over heating? I checked the fuse and the elements. I am a certified eletrician and I understand most of the internals of a dryer. I just want to make sure its the timer before i spend $$. Thanks !!
    Cubby.........
    Yes, it sounds like a timer problem, whats the model# of your dryer?
    Jun 2006
    Pennsylvania
    The model number is 110.96573220. Where can I find a cheap timer? Thanks ! Cubby.......
    Before buying a timer, check that lint hasn't clogged your motor causing it to overheat and shut down.
    These links will help you access your motor:
    http://www.applianceaid.com/wpdryer_how-to.html
    http://www.applianceaid.com/slidewpdry.html
    This link explains about motor issues:
    http://www.applianceaid.com/wp-motors.html
  1. Kenmore 90 series timer stops at end of wash cycle
    By petemcg in forum Sears Kenmore
    Last Post: August 10th, 2006, 09:38 PM
  2. Kenmore 70 Series (stops after a few minutes)
    By bsizemore in forum Sears Kenmore
    Last Post: May 13th, 2006, 06:39 PM
  3. Kenmore 90 Plus Series intemittently stops
    By Windhlz in forum Sears Kenmore
    Last Post: February 19th, 2006, 11:41 PM
  4. kenmore 90 series dryer starts and stops
    By kobera in forum Sears Kenmore
    Last Post: January 31st, 2006, 01:11 AM
  5. Replies: 3
    Last Post: December 10th, 2005, 05:07 PM
