Results 1 to 4 of 4
Thread: Whirlpool side by side fridge/freezer stopped making ice
    Nov 2006
    New York
    Default Whirlpool side by side fridge/freezer stopped making ice
    I have a Whirlpool fridge model GS5SHGXKS00 Stainless Steel and the ice maker stopped making ice. The lever is down and no water comes into the ice maker and arm that pushes ice out does not move. Also the water that comes out of the dispenser taste horrible even after changing filter cartridge. Any suggestions?
    Here's a good starting point link:
    http://www.applianceaid.com/icemaker.html
    Check to make sure your ice maker fill tube in the back of your ice maker is not clogged with ice, preventing the water to go in the ice maker.
    You may need an external water filter that connects in-line with your water supply line tubing that connects to your refrigerator to help with improving the taste.
    Nov 2006
    New York
    The tube behind the tube is not frozen but I do notice that there is no water coming from the tube that feeds into the icemaker. Any suggestions? FYI...the water dispenser portion works.
    It sounds like your water inlet valve is bad.
    Here is a new one for your model:
    Water inlet valve kit
  1. FIXED: Whirlpool ice maker water fill tube and cup freezing up
    By NDS in forum Whirlpool/Roper/Estate
    Last Post: July 22nd, 2013, 03:12 AM
  2. FIXED: Whirlpool side by side not dispensing ice
    By TimBuch in forum Whirlpool/Roper/Estate
    Last Post: March 21st, 2013, 04:14 PM
  3. Whirlpool ice-maker keep making ice after ice-bin full
    By ysp in forum Whirlpool/Roper/Estate
    Last Post: December 7th, 2006, 06:30 PM
  4. Whirlpool side by side model Ed5SHAXMQ10 no ice help!
    By Ryan Hargett in forum Whirlpool/Roper/Estate
    Last Post: November 6th, 2006, 12:45 AM
  5. whirlpool side by side refridge - no ice
    By edna in forum Whirlpool/Roper/Estate
    Last Post: October 4th, 2006, 01:34 PM
