Results 1 to 7 of 7
Thread: Jenn-Air Downdraft Range error code F1-7
    Nov 2006
    Jacksonville, NC
    Angry Jenn-Air Downdraft Range error code F1-7
    I recently purchased a used Jenn-air range (looks similar but older than Model #JES9860B). It has a wiring diagram in the bottom kick panel with that reads File/Part No. 8104P696-60 in the corner. I plugged it in and it started beeping and flashed error code F1-7. The burners worked but nothing else. Any help would be great.
    Nov 2006
    Jacksonville, NC
    Default Updated problem (Jenn-Air error code F1-7)
    I checked the range again. When I plug it in, it reads "power interuption" twice. It starts beeping. It then says to set the clock. About a minute later, it starts beeping like crazy and reads the error code "F1-7" and says to contact a service tech. When I tried the burners (they are the ceramic electric I think, they have a flat piece of glass covering the heating elements), no matter what setting I set them to it seems like they heat to the highest setting, then I hear a click and it looks like it shuts off. Nothing else works (fan or stove). Some of the buttons on the control panel will beep when I push them, but no visual change.
    Thanks again for the help.
    It sounds like your control board assembly is bad, thats a very costly part.
    Nov 2006
    Jacksonville, NC
    Default Control Board Assembly
    Do you know where it is located on the range and what it looks like? The person I got the stove from has another one just like it, and I might be able to convince him to let me take the control board assembly off the other one.
    We would need you to post the model# of your range here to see.
    Nov 2006
    Jacksonville, NC
    Default Model #
    Model #JES9750AAB
    S/N 15716191AE
    Thanks again
    Its #5 here:
    http://www3.sears.com/imaging/ImageP...&titleID=00003
    Here is a new one for your model:
    Clock w/harness
  1. replacing burner jenn air cook top
    By nancy73088 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 18th, 2007, 10:38 AM
  2. Jenn Air range JGR8750ADW
    By sadiedog1 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 11th, 2007, 05:05 PM
  3. Problem with Jenn air down draft slide in range.
    By jerr462 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 9th, 2007, 11:36 PM
  4. new Jenn air burner valve, Leaking?
    By EricT in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 9th, 2006, 01:18 AM
  5. Jenn Air Downdraft Cooktop Replacement
    By mfrank2109 in forum Antique and Retro Appliance Chat
    Last Post: October 5th, 2006, 11:39 PM
