Results 1 to 10 of 17
Thread: Whirlpool super capacity 465 oven not working. Repair Manual
    Dec 2006
    Rhode Island
    Default Whirlpool super capacity 465 oven not working. Repair Manual
    Model Number: SF310BEGW
    Hello, I have a Whirlpool super capacity 465 oven. This is a gas model with an electronic ignition, the cook top works fine but the oven all of a sudden will not work at all.
    Thanks in advance for any help.
    Jerry
    I found a thread that is similar to your issue: Another WP 465 issue
    I would first check for 120 volts at your oven glow bar, you will need a volt meter.
    Here is a similar thread: FIXED Whirlpool SF395LEEQ0 - Oven not lighting
    Just dis-connect it and put your volt meter probes in the 2 red wires side and turn on your oven, if 120 volts is present, then your oven glow bar is bad.
    Here is the repair manual for your model: http://adcxns1.whirlpool.com/Service...LE/4322089.pdf
    Here is the troubleshooting flow chart as well for these models: www.applianceblog.com/manuals/DSI_manual.pdf
    Here is your glow bar in case you need to order it:
    Whirlpool 4342528 Oven Bake and Broil Igniter
    Dec 2006
    Rhode Island
    Hey Jake I did what you said and I am getting a reading of 118, so it appears as I will have to replace the glow bar. Also when I was testing this I made a dumb move on my part one of the volt meter probes slipped out of the oven connector without think I putting it back in and blew a fuse at the breaker box, after resetting the breaker (and cursing at my self) I checked again and now I am only getting a reading from one of the red wires so I think I might have fused the connector on the long red wire that connects the glow bar to the dial. Can I order both of these items from you or do you have a link I can access? Thanks.
    Jerry
    I don't understand how it tripped the breaker? If a meter probe falls out and you put it back in it shouldn't trip the breaker, unless it touched your metal range chassis.
    Just order the glow bar, that should take care of it.
    Dec 2006
    Rhode Island
    Thanks for the help Jake, I'll give it a try.
    Ok, sounds good JS.
    Keep us posted.
    Dec 2006
    Rhode Island
    Hey Jake, the glow bar arrived today and I installed it, but the oven is still not working. Also when I switch the oven on I am not getting the gas hiss.
    Thanks for the help,
    Jerry
    Dec 2006
    Rhode Island
    Jake the glow bar they sent me is the round one my stove has the square one will the round one work or no?
    They changed to the round ones now on this model.
    It should work, check again if you are getting 120 volts at your glow bar.
    Does the glow bar glow orange?
  1. Whirlpool super capacity 465 oven not working but burners are
    By Isujustice05 in forum Whirlpool/Roper
    Last Post: December 9th, 2013, 01:46 AM
  2. Replies: 3
    Last Post: December 27th, 2011, 07:24 PM
  3. Whirlpool Super Capacity 465 Oven not working
    By JRJohnson in forum Whirlpool/Roper
    Last Post: July 30th, 2011, 01:31 AM
  4. Whirlpool super capacity oven not working
    By jeromeo in forum Whirlpool/Roper
    Last Post: December 5th, 2010, 11:50 AM
  5. Whirlpool Super Capacity 465 Gas Oven not working
    By whirlmamma in forum Whirlpool/Roper
    Last Post: November 9th, 2005, 07:07 PM
