Page 1 of 24 12311 ... LastLast
Results 1 to 10 of 234
Thread: [FIXED] GE side by side fridge side not cold
    Jun 2005
    Post [FIXED] GE side by side fridge side not cold
    My GE side by side fridge is not up to par on the fridge side. The freezer seems good but a few weeks ago I noticed some water below in the front of fridge on floor and now the fridge side is not cold enough. I turned the dial up to 9 and it still seems warm. Any thoughts?
    Oct 2004
    Post imported post
    Model#?
    Evaporator fan in the freezer working? Any frost on the freezer back wall?
    Some common trouble makers.... http://www.applianceaid.com/frig_notcold.html
    Appliance Repair Aid
    Jun 2005
    Post imported post
    Found some frost on back wall and I can hear the fan and feel air at vent control in fridge side. I wonder if I let it defrost long enough. Or is it possible the defrost unit is malfunctioning.
    Oct 2004
    Post imported post
    **I wonder if I let it defrost long enough. Or is it possible the defrost unit is malfunctioning**
    One way to tell...access the cooling coils ( evaporator ) in the freezer and let us know what you see....
    Pic from Appliance411
    Pic from ApplianceAid
    Jun 2005
    Post imported post
    I took cover off as recommended and you were right Jeff1. Thanks
    Oct 2004
    Post imported post
    Was the evaporator coil totally frosted up or just partially frosted like in the photo above?
    Appliance411.com
    =D~~~~~~
    Jun 2005
    Post imported post
    It did have quite a bit of ice. The thermostat was faulty and replaced.
    Oct 2004
    Post imported post
    Clear "ice" or white snow-like "frost"? It is an important distinction when dealing with refrigerator problems.
    Was the build-up uniform across the whole evaporator coil or just on part of it like the picture shown above? If just part of it, you may have other problems as well.
    The defrost termination thermostat I assume??
    Glad to hear you found the defective part. Hopefully it was the only problem.
    Appliance411.com
    =D~~~~~~
    Jul 2005
    Post imported post
    Glad I found this board.
    I have a GE with similar problems. I first noticed that the fridge was not cooling as well as it should (freezer seemed fine)...put a thermometer on the middle shelf and it registered at 55 degrees - not good.
    I vacuumed out underneath the fridge of some (but not much) dust and cleared ice out of the upper and lover pass-throughs (most of it was in the lower, which was completely blocked). I also removed the back cover of the freezer and found snow-like frost (no ice) on the bottom 1/2 of thecoils (looked just like the photo above). There was ice 'pooled' up in the bottom of the freezer, but the drain hole was not plugged. There was also a pool of water in the bottom of the fridge.
    The fan at the top of the freezer is blowing...but I haven't heard the fridge make any other noises the last couple of days....just the quiet hmmm from that. Ido not think I hear a compressor turn on and off.
    I used a hair-dryer to takethe snow off and put it all back together...this was yesterday. Today (18 hours later) the fridge is down to 40.
    A couple of questions: 1. I see two hanging wires (one white, one grey)with male terminals coming from up top and resting on the top of the cooling coils behind the back panel. They do not seem to go anywhere.- what are there and could they be part of the problem?
    2. Should I give it another day to see how all works out?
    3. Is there something else I should try?
    I am fairly good with little 'fix-it' projects, including wiring,and would prefer saving $$ on a repair man - UNLESS this is surely one for the pros.
    Kevin
    Oct 2004
    Post imported post
    Since you haven't told us which model of GE refrigerator you have (they're not all the same), it is impossible to say without being there ourselves to check it out. But you'd likely have to check the wiring diagram right on the fridge itself to determine what those wires are for.
    JFYI. You can read about where to locate the model and serial number identification tag on your appliances at the following link:
    LINK > Model Number Tag Search
    Today the fridge is down to 40... Should I give it another day to see how all works out?
    If it seems to be working, I don't see why not.
    JMO
    Appliance411.com
    =D~~~~~~
  1. kenmore elite fridge side not cold
    By EdBurkett in forum Sears Kenmore
    Last Post: November 22nd, 2008, 10:41 AM
  2. Jennair fridge side not cold after defrost
    By wobbletop in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 20th, 2006, 01:48 AM
  3. ge profile performanceside by side fridge side not cold
    By jeffreyrae in forum GE/Hotpoint
    Last Post: September 10th, 2006, 12:17 AM
  4. msd2465ge - Fridge side not cooling
    By MarkF2 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 31st, 2006, 12:43 PM
  5. Side X Side Fridge Still Doesn't Get cold Enough
    By hog100 in forum Refrigerators & Freezers
    Last Post: July 22nd, 2005, 04:53 AM
