Results 1 to 2 of 2
Thread: KitchenAid Oven Failure
    Dec 2006
    Fiji
    Default KitchenAid Oven Failure
    Our KitchenAid oven won'l light. Model #KGSC308LSS0, serial #IMP2866510. In the past, the ignitor would glow, but the oven would only light intermittently. Now, no glow, no oven. Our problems with the stove are compounded, since we live in Fiji (big tech commute cost), and run our power through a 220V-110V step-down transformer from our 220V generator. But we have new generation inverter with clean power that works for our electronics, computer, etc. Cook top works fine.
    I would first do a voltage check at your oven igniter for 110 volts. If you are getting 110 volts and your igniter is not glowing then you would need a new igniter.
    Here is the one for your model you can order if you need to:
    Ignitor, oven burner
  1. Whirlpool Super Capacity 465 Gas Oven failure
    By IanW in forum Whirlpool/Roper
    Last Post: December 16th, 2010, 12:16 PM
  2. KitchenAid Superba Oven Dim Control Display
    By Arnhemjim in forum KitchenAid
    Last Post: June 10th, 2007, 09:41 PM
  3. Kitchenaid kebs208dss10 double oven trouble
    By Ann Foust in forum KitchenAid
    Last Post: April 5th, 2007, 11:20 AM
  4. KitchenAid Superba KEMS307D8S6 Oven problem
    By jbow345305 in forum KitchenAid
    Last Post: March 24th, 2007, 11:32 PM
  5. Kitchenaid Oven F3 Code
    By DJUecker in forum KitchenAid
    Last Post: February 20th, 2006, 09:21 PM
