Results 1 to 10 of 18
Thread: kenmore elite front load washer won't run
    Jul 2005
    Post imported post
    my washer suddenly won't start. The light blinks for the type of load but when i hold the start button nothing happens. I have cleaned out the soap dispenser and find no obstructions. any ideas?
    Post imported post
    If you can please post the Model# that would help us.
    Any other sounds like a humm or click when you try to start it?
    Jul 2005
    Post imported post
    sorry it is a kenmore elite he3
    model # 110, 42832 201
    it doesn't make any noise, the light on the selector button just flashes.
    Post imported post
    I would open the bottom access panel, by removing the 3 torx screws on the very bottom of the machine, then you will see a tech. guide sheet wrapped in plastic mounted on the right side of the inside panel.
    It has lots of basic trouble-shooting in it.
    Jul 2005
    Post imported post
    thanks jake ,
    i will try your suggestion.
    Jul 2005
    Post imported post
    I have the same problem (LED's blink but machine does not start), but my HE3 is model is slightly different: 110.42822200.
    There is no hum or click when I try to start under any of the washmodes (normal, heavy, etc.). HOWEVER, if I push the "drain/spin" button, set the spin speed to "no spin" and push the "start" button, then I hear a faint click. What do you recommend? Thank you!
    Post imported post
    Rodney, Try what i asked Jen to do, check that trouble-shooting guide. Since this machine is mostly electronic/computer controlled, its hard to say without looking at that guide.
    Jul 2005
    Post imported post
    Thanks Jake. I will give this a try.
    Jul 2005
    Post imported post
    $170.00 later i have found out that a pin broke off on the door ,it tells the machine that it is locked. the repair man told me that it happens a lot and people don't realize that when you empty the machine you inadvertently pull the wet clothes across the pin and break it of with out even knowing. i hope this will be helpful to anyone in the future.
    Post imported post
    Thanks Jen for the update and information about the door,
    I don't see that happen much here at all in Oregon, But things can happen more in some parts of the Country more than others.
  1. Replies: 14
    Last Post: June 8th, 2010, 11:04 AM
  2. Kenmore Front Load Washer Spin Noise
    By jhooper in forum Sears Kenmore
    Last Post: April 24th, 2007, 09:48 AM
  3. Kenmore Front load washer (bry Fridigaire) year 2000
    By codycattle in forum Sears Kenmore
    Last Post: July 19th, 2006, 02:34 AM
  4. FIXED: [FIXED] Kenmore 417 Front load washer
    By in forum Sears Kenmore
    Last Post: October 12th, 2005, 12:55 PM
  5. Kenmore front load washer not spinning
    By nytrus in forum Sears Kenmore
    Last Post: September 26th, 2005, 07:08 AM
