Results 1 to 6 of 6
Thread: Kenmore Elite Gas Dryer error code e2
    Jan 2007
    Fair Oaks, CA
    Angry Kenmore Elite Gas Dryer error code e2
    Model Number: 110.70052990
    I have a Kenmore Elite Gas Dryer model # 110.70052990. When I turn it on the motor runs for about 1 minute then shuts off with an E2 error. Here are the things I've done to troubleshoot.
    1. Verified the gas unit turns on manually (shorting out the timer relay on the control board). The glow wire turns on and ignites the gas.
    2. Replaced the Control Board with a refurbished unit (no change in error code)
    What input to the control board is required to activate the timer relay?
    Make sure you have good air flow through the dryer, very important!
    If your air flow is good, then the problem is your thermistor, I have changed many of these before due to this problem.
    Here is a new thermistor you can order:
    Whirlpool 8577274 Dryer Thermister - AppliancePartsPros.com
    Jan 2007
    Fair Oaks, CA
    Angry Thermistor Location
    I went ahead and purchased the thermistor but now I can't locate it in the machine. I see the thermal fuse and thermal switch on the blower housing. I also see the flame detector and high temp cutout on the gas heater tube. Is there anywhere else I should look?
    Regards,
    Paul
    The thermistor is just to the right of your thermal fuse on the blower housing.
    Look at this parts diagram: http://c.searspartsdirect.com/lis_pn...0077-00003.png
    #42 is your thermistor, #59 is your thermal fuse.
    Jan 2007
    Fair Oaks, CA
    Talking All OK
    I just replaced the thermistor and tada! It works! Thank you for your patience. I was just hesitant to install something that looked totally different.
    Excellent, good job fixing it, glad its back to normal.
  1. Replies: 1
    Last Post: May 13th, 2013, 03:07 PM
  2. Kenmore Elite error code F0
    By normanjp in forum Sears Kenmore
    Last Post: March 8th, 2012, 05:17 PM
  3. Kenmore Elite Error code F11 & F5
    By lids1 in forum Frigidaire/Tappan/Electrolux
    Last Post: November 19th, 2011, 01:25 PM
  4. Kenmore Elite Error Code 1
    By trishhansen in forum Sears Kenmore
    Last Post: October 4th, 2011, 11:59 AM
  5. Kenmore Elite F13 PF error code
    By kjmac14 in forum Sears Kenmore
    Last Post: December 3rd, 2007, 07:31 PM
