Results 1 to 9 of 9
Thread: Model AFD2535DEW No refrigerator cooling; freezer ok
    Jan 2007
    San Dieg
    Default Model AFD2535DEW No refrigerator cooling; freezer ok
    Well, my title says it all. This unit is about 18 months old. Is there a motor or something that is supposed to periodically re-direct air from the freezer to the
    refrigerator? By the way, this is a bottom freezer, french door style. It's covered under an extended warranty, but they can't/won't come out until Friday. The warranty company is sending out A&E Factory Service, and I've not seen much good written about them. I'd like to be armed with some info ahead of time! On the inside top rear panel, there is a plastic enclosure. If I turn the cooling control to off, wait a bit, then back to '4', I hear a bunch of gear/motor noises coming on, then they stop.
    Ideas? Thanks in advance for your insight!
    So you freezer is freezing everything really good, but its not so cool in your refrigerator section?
    Put your hand in front of #7 here:
    http://c.searspartsdirect.com/lis_pn...5005-00007.png
    Thats your cold air damper that puts cold air into your refrigerator section, if you don't feel much air coming out, then its likely your evaporator fan motor, or an ice/frost clog in your air tunnel that goes from your freezer up to your refrigerator damper.
    If you hear a bunch of gear/motor noises when you turn it back on, then the noise completely stops? or is your evaporator fan in your freezer still blowing cold air in your freezer?
    Jan 2007
    San Dieg
    That's correct-no air flow into the refrigerator section. The motor/gear noise I hear sounds like something is cycling through its paces, then stops. But it only makes the noise if I turn the temp selector until two dashes are displayed, wait a few seconds, then return them to their previous settings. There does seem to be some air flow within the freezer section. I can see a fan moving if I pull the unit away from the wall and look at the left-rear corner.
    Does this help?
    That fan in the back is your condenser fan, the one I'm referring to is inside your freezer, put your hand over the freezer vents to see if lots of cold air is coming out. Do you hear your freezer fan running at all either?
    Jan 2007
    San Dieg
    Think you might have nailed it. The compressor runs, as does the condensor fan. There is little, if any, air movement in the freezer compartment. Took the bottom back panels off to clean the rear of the coils and the fan, but can't locate the evap. fan you mentioned. Is it in a sealed portion of the unit?
    Eric
    Here is the parts diagram for your model:
    http://c.searspartsdirect.com/lis_pn...5005-00010.png
    #4 is your inside freezer back panel, #18 is your evaporator fan motor.
    #8 is the screws that mount your evaporator fan to the motor support bracket.
    Jan 2007
    San Dieg
    All fixed now! Thanks for your guidance. I actually had a friendly repair crew who really got a chuckle when I suggested this as the problem. They had a replacement kit on the truck and got it changed out in no time. We are back in the cooling business! The motor they took out was encased in a plastic housing. The replacement looks heavier duty and really moves the air.
    Thanks Jake!
    Excellent, glad that was it, and glad its all back to normal again.
    Here is a new evaporator fan motor for your model, in case others need to order it:
    Freezer (evaporator) fan motor
    Sep 2011
    stow, ohio
    Default Freezer works, but fridge is warm
    I have a Kenmore bottom freezer unit that the freezer works but the fridge part doesnt. Any ideas?
  1. Bottom freezer model 596
    By dms in forum Sears Kenmore
    Last Post: October 28th, 2013, 10:40 PM
  2. Replies: 5
    Last Post: February 26th, 2012, 06:06 AM
  3. Frost Buildup in Freezer (model 106.63182302)
    By grundi in forum Sears Kenmore
    Last Post: May 27th, 2007, 11:20 AM
  4. Replies: 2
    Last Post: December 3rd, 2006, 02:03 AM
  5. Replies: 4
    Last Post: October 18th, 2006, 05:06 PM
