Results 1 to 6 of 6
Thread: Ice sticking together in receiving tray
    Jan 2007
    Midlothian, VA
    Default Ice sticking together in receiving tray
    I have a side by side (ED27PQXFN02) and recently the ice has been clumping in the tray. Ice is producing for the most part fine, but occasionally a few cubes are hollow. The bar gets stick in the ice and I have to knock it loose so it can raise to dump the ice. The blades have frozen water drops on them pretty much all the time. The compressor was replaced about 3 years ago. Sometimes I also see tiny ice crystals on the frozen food bags/boxes. I just checked and temp in the freezer is -5 and 36 in the fridge. I don't remember the freezer being that cold before. Thermostat was replaced last summer/fall. Freezer is set on B and fridge is set on C - both I think factory settings. Any ideas would be appreciated. Thanks.
    I would check your door gaskets to make sure you don't have warm air leaking in, also check your ice dispenser door, to make sure thats closing good after you get ice from your dispenser.
    Here is a ice door chute kit, in case you need to order it:
    Ice chute door kit
    The hollow cubes are caused by a low water issue to your ice maker as described here:
    http://www.applianceaid.com/icemaker.html#hollow
    Jan 2007
    Midlothian, VA
    Thanks Jake. I checked the door gasket and there is suction when I try to open it. I also pushed on the ice dispenser door and it appears to shut firmly. Are there any other checks I can do with them? Is it normal for the freezer to be sub 0 on that model?
    The normal temp. of all freezers should be 0-10 degrees.
    -5 is colder than normal, but that shouldn't cause the ice cubes to stick.
    Jan 2007
    Midlothian, VA
    OK, here's a followup. Because of the sometimes hollow ice cubes, I took your advice and pulled off the water inlet valve. To my gross surprise, black water started coming out of the supply tube, and I'm on county water. It took 5-6 glasses to clear up, but the cubes in the tray were clear??? Water pressure was strong. So, I replaced the water inlet valve and it looks like that has cleared up the problems with ice clumping and the hollow cubes. Thanks Jake.
    Glad that new water inlet valve fixed it for you.
  1. FIXED: Whirlpool ice maker water fill tube and cup freezing up
    By NDS in forum Whirlpool/Roper/Estate
    Last Post: July 22nd, 2013, 03:12 AM
  2. frigidaire ice maker leak
    By icemanTO in forum Frigidaire/Electrolux
    Last Post: September 28th, 2008, 08:25 PM
  3. Whirpool Conqest Gold Side by Side Ice Maker Problem
    By tadpole88 in forum Whirlpool/Roper/Estate
    Last Post: September 21st, 2007, 12:29 PM
  4. Ice Maker problems
    By cynergy in forum Sears Kenmore
    Last Post: October 4th, 2006, 07:41 PM
  5. Kenmore Ice Maker leaking into tray
    By tomshe in forum Sears Kenmore
    Last Post: September 8th, 2006, 01:31 PM
