Results 1 to 6 of 6
Thread: Maytag LA512 series 10 leaking
    Feb 2007
    Ohio
    Default Maytag LA512 series 10 leaking
    Seems to only leak when it is filling. Leak seems to come out from under the back left hand side (when you are standing in front of it facing the control panel) which seems to indicate some issue with maybe a leaky hose or valve when it is filling? I can't see anything without taking it apart and then don't know if I'll know what to look for. The model is Magtag LA512 series 10. Any helpful advice for where to look would be appreciated.
    Yes, I used to run across this issue in the 80's through the mid-90's. You injector valve has gone bad when its filling with water.
    They have made a new kit for this, which includes the small clamps as well, as some can get very rusty after being on a washing machine for many years.
    Here is a help link to get access to this part:
    http://www.applianceaid.com/maytagwash.html#apart
    Here is a photo of where the part is located on the top left side:
    http://www.applianceaid.com/images/maywashfillleak.JPG
    Here is the injector kit you can order:
    Water inlet injector tube & nozzle kit
    Feb 2007
    Ohio
    Thank you Jake! I called the 800 number and ordered the water inlet injector tube & nozzle kit today. This forum is wonderful and I really appreciate your fast response!
    Its easier to just order it from the link I posted(click the photo of it), no calling necessary.
    Feb 2007
    Ohio
    This 53 year old Grandma was easily able to replace the injector valve with the kit and your instuctions!! Total for my repair was $13.60 which included the shipping!! Jake, thank you SO much!!
    Excellent Dellarango, glad you got it fixed and its back to normal.
  1. Maytag Freezer leaking water
    By RNS in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 28th, 2011, 10:39 AM
  2. Maytag Legacy series dryer walks
    By Jann K in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 3rd, 2007, 08:41 PM
  3. Maytag Performa leaking when filling
    By soaked in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 25th, 2006, 09:14 AM
  4. maytag Atlantis MAV7600AWW leaking & pivot spring/plate
    By taz1 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 9th, 2006, 11:34 AM
  5. Leaking Maytag top Load Washer
    By maroonedinnj in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 22nd, 2005, 11:46 AM
