Results 1 to 8 of 8
Thread: Neptune motor control board burn out
    Feb 2007
    fairfax va
    Default Neptune motor control board burn out
    I have a Maytag Neptune 5500. Thanks to your site I found the sheet of paper hidden inside the machine control area. I followed the instructions and found the problem - the motor control board is burnt up. Something caused the control board to fry. Any idea of what might have caused it? Paying $200 for a new board hurts enough, but finding out the board will burn again....
    Any advice would be appreciated.
    I'm assuming its the MAH5500 model?
    On these models door wax motor was the main cause of that main control board failure.
    Here is lowest price I found on the main control board for your model, in case others need to order it.(click photo for pricing/ordering information):
    Here is the wax motor for the door lock/latch:
    Mar 2007
    Connecticut
    Default MOTOR control failure
    It looks like the issue is the motor control, not the machine control. My 5500B has the same problem - one of the MOSFETS on the motor control board smoked.
    My 5500b does not have the "wax motor" door latch, rather the traditional solenoid actuator. Mine is 6 years old - don't know when they stopped using the wax motor that was indeed responsible for failures of machine control board.
    It further looks like the motor/control has been upgraded to a different type and the original control board is not available. I checked my existing motor - it appears fine, I'm going to try and repair the control board rather than spend $200.
    Dave
    Jun 2007
    MD
    Quote Originally Posted by drichct View Post
    Dave
    Dave,
    Were you ever able to repair the motor control board?
    Dec 2008
    Redlands
    Default maytag neptune 5500 motor control board failure
    The motor board of the Maytag Neptune 5500 has been doing funny things in the last few weeks. The control lights switch from one another and navigate through the board panel. Sometimes they do not respond to pressing. Today they do not respond at all. After dusting off the board, and letting the machine rest unplugged, we tried a few more times without success. When we were about to commit suicide, the machine began to work, but we don't know for how long.
    It seems that something is wrong with the electronics of the motor control board of some other component in the area, because the door seems to lock OK and the engine works fine.
    Any help before I spent 200+ in a technitian?
    Balaena
    Hi Balaena,
    Check your warranty, you should have a 10 yr. warranty on the motor.
    Read this thread, you may not have to pay anything to get this motor conversion kit:
    http://www.applianceblog.com/mainforums/showthread.php?t=11263
    Here's the one for your model you would need:
    Part#12002039.
    Motor/control conversion kit, Neptune washer
    Dec 2008
    Redlands
    Jake:
    I'm sorry for the misunderstanding, but it is not the motor, but the motor control board, the plate that has a bunch of electronic circuits, placed on top of the washer. The folded paper with instructions call it "motor control board" I think that that is the part that is failing, because the motor (engine) was working OK.
    That board in the console is the machine board.
    The motor control board is mounted down below on your washer base below your tub.
  1. GE JVM2070SK - 2nd control board dead
    By dfenwick in forum GE/Hotpoint
    Last Post: June 4th, 2011, 07:23 AM
  2. [FIXED] Another Kenmore Dryer problem
    By NoTalent in forum Sears Kenmore
    Last Post: April 14th, 2009, 12:31 AM
  3. motor, motor control or control board???
    By bosshogg in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 21st, 2007, 12:02 PM
  4. Maytag Neptune Control Board Issue
    By tim205 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 17th, 2007, 11:46 PM
  5. Even Heat Board Fried in Kenmore Elite 110.73942101
    By caliamara in forum Sears Kenmore
    Last Post: December 10th, 2006, 10:55 AM
