Results 1 to 4 of 4
Thread: Kenmore Washer Model 110 82427800 Is dead
    Mar 2007
    NC
    Default Kenmore Washer Model 110 82427800 Is dead
    My washer has just died.. It won't fill, agitate or anything. The outlet has power. Is there any kind of fuse or reset button on the washer itself?? Please Help..
    Mar 2007
    NC
    I also used a piece of wire to bypass the lid switch but still nothing..
    Mar 2007
    NC
    No, there's no fuse or anything that you can reset.
    You would need a volt meter and test the voltage coming into your machine inside the console, if you get 120, then its likely your timer is dead. You can get a cheap volt/ohm meter at Radio Shack.
    Here is a link to take it apart, if you plan to do it yourself:
    http://www.applianceaid.com/procedures.html
    Here is a new timer for your model, in case you need to order it:
    Timer
  1. Kenmore model 417 washer won't spin
    By gpress in forum Sears Kenmore
    Last Post: March 19th, 2014, 07:50 AM
  2. Kenmore 90 Series Washer model 110.20922990
    By chowoo in forum Sears Kenmore
    Last Post: May 1st, 2007, 09:48 PM
  3. Kenmore Model 80 Washer and Dryer - how old?
    By philbee62 in forum Sears Kenmore
    Last Post: March 27th, 2006, 01:01 AM
  4. Kenmore 80 Series Model 110 Washer 92581110
    By nowakinc in forum Sears Kenmore
    Last Post: July 12th, 2005, 09:22 PM
  5. Kenmore Washer Model 110 Just Dead
    By Lodestone in forum Sears Kenmore
    Last Post: July 10th, 2005, 07:19 PM
