Results 1 to 8 of 8
Thread: kenmore 417.40042990
    Apr 2007
    louisiana
    Default kenmore 417.40042990
    Yesterday, the washer made a loud thump sound so I ran to the washer and turned it off. When I took off the cover, I found a piece of the shell was lying in the bottom of the machine. It had just broken off. When I called Sears to see if any defects were reported with the shell, they said no and the best route was to schedule a tech to come. The local repair shop had the same machine in for a repair with the same piece broken off. What's up? The machine was running fine. My wife is in a tizzie as we have company coming tomorrow. Any advise is appreciated. Thanks.
    Thats odd I rarely see that happen, can you tell if its from the front or back of the shell in this parts diagram here:
    http://www3.sears.com/imaging/ImageP...&titleID=00003
    Any water leaking?
    Apr 2007
    louisiana
    It's the back shell, see attached pictures and there is no water leakage. Thanks.
    [ATTACH]Attachment 551[/ATTACH]
    Attachment 552
    Attachment 553
    Very interesting, I've never seen it break there on this model.
    Have you attempted to try to do another load again, to see if it still washes and spins normal?
    Apr 2007
    louisiana
    No, I haven't tried to run the washer. Won't it leak when it spins during the wash cycle or drying?
    Apr 2007
    Portland, Maine
    Default Shell
    Hello, I agree with Jake. I haven't seen any outer tubs break like that either! If it is under warranty I would have a tech come replace your outer tub. If it is out of warranty, it will be expensive to repair. I wouldn't suggest running it with broken shell however....
    Hope that helps
    Jon
    Apr 2007
    louisiana
    Any chance this could be a design defect? I have a Sears tech scheduled, but the machine is 7 years old. I'm hoping for a defect designation by the tech. thanks.
    No, I wouldn't think it would be a design defect, because the other techs and I would have seen these break there where yours broke on other people's washers too.
    Let us know what the tech. says.
  1. Kenmore Fridge (freezer) not cooling properly
    By mattpaul in forum Sears Kenmore
    Last Post: April 16th, 2007, 10:02 AM
  2. Kenmore 94152 melting synthetic fleece
    By swienke in forum Sears Kenmore
    Last Post: December 23rd, 2006, 05:16 PM
  3. Kenmore 665.15932000 versus Maytag MDB8751
    By russell g in forum Sears Kenmore
    Last Post: October 17th, 2006, 01:21 PM
  4. washer drain hose for Kenmore 417.40042990
    By Bendix_NY in forum Sears Kenmore
    Last Post: January 14th, 2006, 03:59 AM
  5. Another Kenmore with no Heat
    By tickedntexas in forum Sears Kenmore
    Last Post: February 6th, 2005, 09:05 AM
