Results 1 to 10 of 13
Thread: GE dishwasher will not drain on last rinse cycle
    Jul 2005
    Default GE dishwasher will not drain on last rinse cycle
    Model Number: GSD5940D01SS
    Brand: GE
    I have a GE dishwasher approx. 4 yrs oldmodel # GSD5940D01SS that has water in the bottom of the tub (up to the heating element). I have checked for kinks in the drain hose and have cleaned out the sump entrance screenalong with replacing the nutand piston and flapper valve on the self cleaning body that are common to breaking down on this d/w.
    I hooked the dishwasher back up and watched the entire cycle by leaving off the bottom kick panel. I removed the drain hose and put it in abucket so I can see just how much water is coming out. This dishwasher has a prewash, main wash, and two post/rinse cycles. The first 3 wash cycles work normal I get approx. 2 gallons of water out of each cycle but on the last fill, it does not pumpall the water out of the d/w.
    I getabout 2 cups in the bucket and the rest stays in the bottom of the d/w. I noticed the plunger solenoid retracting and extending and the fan spinning on the motor when it was running during the 4 cycles.I have tried to press the ON buttontwice with in 5- 10 seconds to get the rest of the water pumped out as suggested byGE service but only get about 1/2 of cup to pump out. On the GE website it states the last fill does not use the dual pump system.
    I don't know why it will not pump water out on the last cycle.I have looked ata lot of other posts/forums but have not found anything yet so I signed up here hoping to resolve this problem.
    Thanks David
    Very interesting,
    The drain flapper solenoid may be getting worn out/hot causing it to start sticking after the first serveral drains, causing it not to open up completely during the final drain.
    Thats about the only thing i can think would cause that.
    Oct 2004
    Some pump designs have a rubber 'plug' in the center of the internal drain flapper valve. I have heard of one instance where that plug falling out caused improper drains.
    Sorry but I can't find any pictures showing it.
    JFYI
    Appliance411.com
    =D~~~~~~
    Jul 2005
    Thanks for the suggestions I will let you know what I find out in a few days
    Jul 2005
    Smile
    I found the rubber flapper valve broken/separated and lodged in the 90 degree black hose that connects to the smaller auxiliary pump.
    I ordered it and now everything works great thanks for your help. I should of checked this part out also when I had the d/w out the first time, oh well.
    Aug 2005
    I have model number GSD5940F00SS and this just starting happening to us two days ago. I will see if I find a similar thing. How long did it take to get the part?
    I found it Dan O.,
    Here is the Link:
    GE WD01X10175 Flapper Valve
    There is a video to show you how to get to it and replace it, once you click the link above.
    Oct 2005
    Indianapolis
    Question Follow-up Question to GE Diswasher Not Draining
    Hi. I have a 2000 GE Profile (model #GSD4920Z04BB) that like the original poster, is not draining during the last cycle. I think I have narrowed it down to the "flapper valve" or "solenoid" (the solenoid appears to have "blown" as both the part and the tile underneath the part look fried). My question is, if it's the flapper valve and not the solenoid...where is this valve located on the dishwasher?? Is this a part I can get to without pulling out the dishwasher??
    Oct 2004
    #2 area....piston inside #3 also gives problems...
    Yes, from the inside in the tub:
    GE WD24X10018 Piston & Nut Assembly
    http://www.applianceaid.com/gedishdrain.html
    http://www.applianceaid.com/drain_wash.html#drain
    Appliance Repair Aid
    Sep 2005
    ny
    Default similar issues
    OK I would like to jump in on this one as I have a GE #GSD4030Y72WW that is not cleaning good and occasionally does not drain completely.
    I see that the common culprits are the flapper valve and the nut & piston plunger.
    The nut & piston being located inside the tub under the rear screen (not in the back). This part appears to be good however...
    The flapper valve located on the back was stuck / deformed in the open position. This must not be good.
    In the first post in this thread indicates flapper was replaced then later on indicates that he found the flapper valve had gotton stuck in black hose and replaced it ? Are these two different flapper valves?
    I can't seem to find the part using my model #? It seems the ge web site site sells the entire check valve assembly for $8 +/-???
    thx robert
  1. Replies: 1
    Last Post: November 20th, 2014, 08:28 PM
  2. FIXED: Whirlpool washer washes, then stops at rinse/drain cycle
    By asikora15 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 9th, 2014, 10:38 AM
  3. Replies: 18
    Last Post: January 11th, 2014, 11:43 AM
  4. Replies: 5
    Last Post: March 24th, 2013, 04:50 PM
  5. Replies: 1
    Last Post: December 15th, 2011, 06:33 PM
