Results 1 to 3 of 3
Thread: Kenmore 110.20092993 water level control broken
    May 2007
    San Diego
    Default Kenmore 110.20092993 water level control broken
    Hi, this is my first time here so i'm not sure if i'll get everything tight.
    My problem is that my washer fills up and doesnt stop. From looking at some threads here i think it's the water level control. Only thing is i'v never taken a washer apart. I looked at the back, but didnt want to start removing screws at random.
    Is there a photo of how to fix this? Am i even close in my guess in whats broken?
    thanks,
    Adam
    Apr 2006
    S. Central PA
    You most likely have a hole in or pressure hose came off.. Here is how to take cabinet off
    http://www.american-appliance.com/ca...ewsdesk_id=131
    Behind the console the water level switch you will see a clear hose attached to it.. follow it and remove from machine . Place under water wth finger at 1 end and blow throw and see if there are bubbles fron a pin hole... if none replce the water level switch
    Here is your pressure switch hose:
    Hose for water level pressure switch
    Here is your water level pressure switch:
    Water level pressure switch
  1. Replies: 9
    Last Post: May 16th, 2007, 01:45 PM
  2. Kenmore refrigerator water dispenser drips
    By Mike C in forum Sears Kenmore
    Last Post: February 6th, 2007, 09:57 PM
  3. Whirlpool diagnosis help
    By djpepe in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 30th, 2007, 05:34 PM
  4. Replies: 3
    Last Post: September 1st, 2005, 09:19 AM
  5. Kenmore (Frigidaire) Stackable water level problem
    By Andrew in forum Frigidaire/Electrolux
    Last Post: February 1st, 2005, 11:45 PM
