Results 1 to 5 of 5
Thread: GE Freezer keeps running
    May 2007
    Georgetown
    Question GE Freezer keeps running
    I have a GE freezer (FUF17D) that just keeps running -- it seems as if the temp sensor is simply not causing the compressor to shut off. I placed a freezer thermometer in the cabinet and at the lowest freezer setting (a '1') I am going below the setpoint of -10F (according to the manual).
    The temperature sensor is located on the inside of the cabinet -- is there any way to test this thing to see if that is the culprit?
    Any other ideas?
    May 2007
    Georgetown
    BTW, I noticed this problem because I started seeing ice buildup on the bottom of the freezer and the drain was frozen. I thought that perhaps the defrost cycle was coming on *while* the compressor was still running - causing the water to melt before it could actually drain out. I took the system apart and cleaned out all of the ice, etc.
    Strange. I hope it is just a faulty temp sensor.
    Yes, it sounds like your temp. control is bad. There should be some more letters after the D in your model#.
    Here is the results i get:
    Model NumberModel DescriptionBrand
    FUF17DAARWHFREEZER A SERIESGE
    FUF17DABRWHFREEZER B SERIESGE
    FUF17DACRWHFREEZER C SERIESGE
    FUF17DMARWHFREEZER A SERIESGE
    FUF17DMBRWHFREEZER B SERIESGE
    FUF17DMCRWHFREEZER C SERIESGE
    FUF17DMDRWHFREEZER D SERIESGE
    FUF17DMERWHFREEZERGE
    FUF17DPARWHFREEZER P SERIESGE
    FUF17DPBRWHFREEZER B SERIESGE
    FUF17DPDRWHFREEZER D SERIESGE
    FUF17DPERWHFREEZERGE
    FUF17DPFRWHFREEZERGE
    FUF17DPGRWHFREEZERGE
    FUF17DTARWHFREEZER A SERIESGE
    May 2007
    Georgetown
    Jake, there are indeed more letters - FUF17DABRWH. I didn't include them because I could never come up with a match!
    Question, of all the part number listed below, do they all use the same temp control?
    Yes.
    Here is the one for your model:
    Part#WR09X10014
  1. Bottom freezer model 596
    By dms in forum Sears Kenmore
    Last Post: October 28th, 2013, 10:40 PM
  2. Why is there a heater in my freezer?
    By Lillian in forum GE/Hotpoint
    Last Post: April 9th, 2007, 07:03 PM
  3. Chest Freezer Help Needed!
    By skilowyo in forum Refrigerators & Freezers
    Last Post: August 30th, 2006, 06:29 AM
  4. amana (scd23vw) freezer not cooling enough
    By adasgupta in forum Amana
    Last Post: July 27th, 2006, 12:00 AM
  5. Replies: 3
    Last Post: February 21st, 2006, 10:30 AM
