Results 1 to 6 of 6
Thread: Hotpoint fridge cooling issues
    Jun 2007
    Utah
    Default Hotpoint fridge cooling issues
    I have a Hotpoint fridge, model HTS22GBMBRWW, that will cool for about two hours and then goes warm (both the fridge and freezer). I can unplug the fridge and plug it back in and the fridge will go through the same cycle - cools for about two hours and then goes warm. I can hear the fridge running when it's cold and when it's warm. I have cleaned the the fridge inside and out, including the coils. Does anyone have any ideas what the issue(s) might be? Thanks.
    Pull your refrigerator out from the wall, then take off your lower back panel and check to make sure your condenser fan is turning. Also when it goes warm, feel your compressor to see if its on.
    Jun 2007
    Utah
    When the fridge goes warm, the condensor fan is running, but the compressor is not.
    Ok, then its likely your compressor relay/overload, motherboard, or compressor itself is bad.
    I would unplug your refrigerator and then take off the compressor relay that mounts to the side of your compressor and ohm it for continuity. If that checks good, do the same for the overload. if both check good, then do a voltage check at the relay/overload to see if you have 120 volts to it, if not then your motherboard is bad, if so then you will need a new compressor.
    You have a 5 yr. parts and labor warranty on the compressor.
    Jun 2007
    Utah
    Default Circuit Board
    It was the circuit board that was bad. I have replaced it, and the fridge works fine. Thanks for your help.
    Ok, sounds good.
  1. Hotpoint Fridge Defrost Timer Location?
    By tony fanucchi in forum GE/Hotpoint
    Last Post: June 20th, 2007, 01:03 AM
  2. Maytag fridge not cooling MSD2356AEW
    By richard tomasetti in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 12th, 2007, 02:18 PM
  3. fix action for my fridge side not cooling
    By akeric in forum GE/Hotpoint
    Last Post: November 21st, 2006, 07:36 PM
  4. Maytag MZD2766GE Not Cooling Fridge
    By Tanjima in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 14th, 2006, 05:34 PM
  5. msd2465ge - Fridge side not cooling
    By MarkF2 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 31st, 2006, 12:43 PM
