Results 1 to 4 of 4
Thread: magic chef fridge leaking water
    Sep 2006
    mesa
    Default magic chef fridge leaking water
    Model number is CTB2123ARA have a magic chef fridge top freezer. Leaking water from defrost drain from inside fridge section. Water does not fall down into control panel funnel intead it hugs the rear section of the fridge and leaks down to floor of fridge and accumulates enough to end up on floor in front of fridge. Was wondering if there is a kit to fix this problem.
    Jan 2006
    Ontario Canada
    Default plugged drain
    Ya there is, unplug the drain, its probably plugged from the drain on down to the pan somewhere.
    Luger
    Sep 2006
    mesa
    Quote Originally Posted by luger View Post
    Luger
    at first thought that was the problem so I pushed a old water vavle line (white plastic one) down the tube to clear out. also put warm water down rear tube. Water comes from freezer down defrost drain but never drips into little cup. It only hugs the wall and eventually ends up on the bottom of fridge section
    Jan 2006
    Ontario Canada
    Default draing problem
    Yes, There is a lot of problems with drain holes being frozen over just enough to make the water LIP to one side missing the drain cup.
    A lot of refrigerators had that problem and manufacturers scrambled to invent a cure(like putting in more heaters in the freezer section) to making the hole bigger. Take 24 hours to defrost the whole frig, unplug it, then plug it it back in it should do the trick for about 1 year or so. IM not sure how old your frig is, but the manufacturer might have your cure as a recall or whatever and fix it for free, get your bill of sale go to the, dealer and confront them with this problem which might have started 1 and 1/2 yrs ago.
    Luger
  1. Replies: 2
    Last Post: September 12th, 2009, 06:45 PM
  2. water on floor under Magic Chef
    By dtorbeck in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 8th, 2007, 01:45 PM
  3. magic chef water problem
    By larry harding in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 16th, 2007, 11:43 AM
  4. Leaking Water inside fridge (Defrost Drain clogged?)
    By phazerwolf in forum Whirlpool/Roper/Estate
    Last Post: January 25th, 2007, 02:11 AM
  5. Maytag MSD2356AE leaking water in fridge (not drain prob)
    By kfree in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 3rd, 2006, 12:38 AM
