Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: Sub-Zero Stand-Alone Ice Maker problem
  1. #11
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    You can temporarily bypass them if you want to check it. They're both single pole single throw or basically on off switches. If you bypass both switches the unit should start.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  2. #12
    Jul 2006
    I'm still looking for the pressure switch.
    Timer 12-1980-21 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Attached Thumbnails Attached Thumbnails Sub-Zero Stand-Alone Ice Maker problem-thermostat-11-0407-21-00855214.jpg
  3. #13
    mjz
    mjz is offline Premium Member
    Jul 2012
    Texas
    Quote Originally Posted by rickgburton View Post
    I am so confident that you found the problem - I am not even going to spend the effort. I am just going to buy the pressure switch and the original timer that created the problem in the first place and the unit will be repaired.
    I might add - there would be no need to bypass the bin switch. It's fine according to my continuity test. I could bypass the pressure switch and just turn the bin switch to "on" and it should work. Like I wrote above - I am so confident now of the diagnosis - that replacing the pressure switch will work.
    I'll let you know once I successfully buy the parts and install them.
    (interesting - the switch is $4.95: V7-3E17D8 - Honeywell - V73E17D8 - datasheet - but I have to buy the whole assembly for easy repair which will cost me $81.00 - lesson learned on not shutting off the circuit breaker).
  4. #14
    Jul 2006
    Were you able to find the pressure switch?
  5. #15
    mjz
    Jul 2012
    Texas
    Yes - that's how I was able to test it. It's right next to the drain pump. Easy to get at.
  6. #16
    Jul 2006
    I was referring to a new pressure switch but I'm glad you mentioned that. Looking at the wiring diagram, the one by the pump, is the "pump pressure switch". The "safety pressure switch" is up by the timer and bin switch.
  7. #17
    mjz
    Jul 2012
    Texas
    Hi Rick - The safety pressure switch and the pump pressure switch are physically right next to each other on the same mounting. In fact, I have to buy the whole unit (both switches) even though only one of the switches is bad. In the picture I posted earlier, I showed only the switch itself which is a $4.00 part. The part below (which I have to get) is an $80.00 part. I can't get the $4.00 part quickly like I can the other one in order to put my ice maker back in operation.
  8. #18
    Jul 2006
    Radio Shack?
  9. #19
    mjz
    Jul 2012
    Texas
    Radio Shack?
    Hi Rick - I just wanted to let you know that the ice maker is all fixed and running like new again.
    It was the high pressure switch which was shorted (my fault for not shutting off the circuit breaker first) and the replacement part I installed today brought power back to the unit just like the schematic you posted above showed.
    There was nothing wrong with the bin switch and it's working normally.
    I also replaced the timer which was the problem in the first place and the ice maker is now cycling properly - it makes ice, flushes the reservoir and cycles like it should. By this time tomorrow I should have ice again to go with my Scotch. Perfectly shaped barrel ice - crystal clear and wet.
    Thanks again for your help - especially the schematic.
    Best,
    Michael
  10. #20
    Jul 2006
    Awesome! You did a good job on the diagnosis and repair!
  1. Kenmore Coldspot stand-alone ice maker 106.89482994
    By beausj01 in forum Undercounter / Freestanding / Stand Alone Ice Makers
    Last Post: September 13th, 2010, 03:20 PM
  2. Kenmore Coldspot 106.89482993 stand alone ice maker not working
    By jeephog in forum Undercounter / Freestanding / Stand Alone Ice Makers
    Last Post: January 5th, 2010, 02:58 PM
  3. Kenmore coldspot 6 (Stand Alone Ice Maker)- lots of noise and small ice
    By Chineras in forum Undercounter / Freestanding / Stand Alone Ice Makers
    Last Post: August 4th, 2006, 10:05 AM
  4. Stand alone Ice Maker
    By RBishop in forum Undercounter / Freestanding / Stand Alone Ice Makers
    Last Post: May 5th, 2006, 10:27 PM
  5. Kenmore Stand alone 106 ice maker
    By graniteman in forum Undercounter / Freestanding / Stand Alone Ice Makers
    Last Post: October 25th, 2005, 08:35 AM
