Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Water Heaters
Water Heaters Sears Kenmore - AO Smith - Rheem/Ruud - General Electric - American - Bradford White - Reliance
Old February 18th, 2008, 08:46 AM
jschneider is on a distinguished road
Default Kenmore Gas Water Heater Shutting off
Hi guys,
Great forums....use them often....great input from your tech guys.
I have a Kenmore Model #153.335550, Serial #B977755234 gas-fired water heater, that is experiencing a shut-off condition after the unit reaches operating temps. It will shut off and extinguish pilot light along with main burners.
I have turned pilot to off, cycled for 5 minutes, relit the pilot (successfully) and the pilot stayed on after one minute (pilot know popped up). Turned knob to ON and main gas burner ignited. This burned for at least 5-8 minutes and then shut off (should be normal operation) but when main shuts off, so does pilot.
Ran this procedure twice - same results. Is this the automatic gas shutoff (water temp) system at fault? If so, how difficult a repair is this? Have plumbed in tanks before and changed out pressure relief valves, but have not dealt with thermostats and the like before this. Any suggestions?
Thanks again for all your great work out there guys.
John
Old February 18th, 2008, 10:30 AM
Hi John,
It sounds like you have a bad thermocouple.
http://www.searspartsdirect.com/part...5621-00001.png
Its #7
Looks like the only place that has it in stock is at Sears. So you can go to your local Sears store to get it.
Its part#H06E-036
Old February 18th, 2008, 10:39 AM
thanks Jake....on my way to the parts house as we speak.
John
Old February 18th, 2008, 10:50 AM
Sounds good John, let us know the outcome.
Old February 19th, 2008, 08:46 AM
It was indeed the thermocouple....and after a few scrapes on the wrists from close quarters, I managed to put the new thermocouple in and fire the unit up. Many thanks again sir.....great input for us working stiffs out there.
John
Old February 19th, 2008, 09:34 AM
Good job installing the new thermocouple John, glad its working good again.
[FIXED] Kenmore Dishwasher goes to next cycle before water full jgaines Sears Kenmore 42 May 15th, 2008 07:23 PM
Reliance 606 water heater, gas marymom Water Heaters 2 November 29th, 2007 02:43 AM
Kenmore ice and water not working sec78 Sears Kenmore 1 July 4th, 2007 11:51 PM
