Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Water Heaters
Water Heaters Sears Kenmore - AO Smith - Rheem/Ruud - General Electric - American - Bradford White - Reliance
Old June 27th, 2008, 07:53 AM
firedogut is on a distinguished road
Default bradford white with small leak need help fast
I have a Bradford White MI40T6EN12 water heater.
from the model number i know it is a 6yr tank Warranty. from the s/n it was made nov 2000.
i have a small leak. can't tell where from yet. right now it drips just below the opening to the pilot. drips once every 3-8 sec. I don't think the tank is bad....only 7 years old.
where else should i look? can the cover come off or be liffted so that i can more?
also a important note. if i turn off the water to the house the drip stops. that is the other reason i don't think it is the tank.
i'm also looking for the manual.....anyone know where i can find it?
Old June 27th, 2008, 08:39 AM
Check where your plumbing comes into the tank to see if its leaking there, you would notice water on top if so thats leaking down either the sides or internally.
Old June 27th, 2008, 10:44 AM
nope the top and all fitting connected to the top to above the heater are dry.
did a drain and flush.......water was clean
uggggg.....sounds like a bad tank?
Old June 27th, 2008, 10:55 AM
if it is a bad tank what brands would you stay away from. which ones would you buy?
uggggggggg only 7 yrs old.
Old June 27th, 2008, 02:15 PM
When I worked for Sears, all the Kenmore water heaters were very reliable.
Rheem & Ruud are good too.
Kenmore 90 Series: Small Leak pierce Sears Kenmore 6 April 5th, 2008 02:32 PM
mah5500bww small leak then overfill laundrysu Maytag/Magic Chef/Admiral/Jenn-Air 3 April 22nd, 2007 11:03 PM
Kenmore 90 Series has a small leak 110.26914690 endermc12 Sears Kenmore 2 July 7th, 2006 05:11 PM
water leak model # 253.71822102 jsos Sears Kenmore 1 February 5th, 2006 10:40 PM
Small White Floating ball smilingdingo Sears Kenmore 3 September 19th, 2005 07:16 PM
