Results 1 to 4 of 4
Thread: Whirlpool Ultimate Care II washer - no drain or spin
    emmittbarks is offline Premium Member
    Jan 2008
    Flagstaff, AZ
    Default Whirlpool Ultimate Care II washer - no drain or spin
    I have a Whirlpool Ultimate Care II washer (model no LSQ8220HQ0) that fills and agitates, but will not drain or spin. A few weeks back the motor couplings/isolation were replaced. It worked for about 8 loads after that. I can hear the timer clicking along, but the motor's not running. Sometimes its smells faintly like the motor is burning.
    Here's what I've checked so far:
    Lid switch: Works mechanically (clicks when closed); ohmeter shows zero resistance when lid is closed, open circuit when lid is open. I have not tried to "jumper" the lid switch wiring harness to make the washer think the lid is closed.
    Pump: Spins okay, nothing appears to be stuck inside.
    Basket/tub: Nothing like a sock wedged in between.
    Drain hoses: No obstructions.
    Timer: I replaced the old one with a new, but still had the same problem.
    Motor couplings: New ones are still intact.
    Motor: This is a two speed motor. Resistance through all the terminals was okay per DIY repair manual. There is no obvious burning on the windings.
    Motor start switch: Continuity tests okay with ohmeter per DIY repair manual.
    Gearbox, clutch, brake tube, drive block, dog cams: Seem to work, at least nothing is obviously wrong.
    Capacitor: When I shorted the capacitor (discharged the built-up charge) and switched the wires to the 2 terminals (they are both red), the washer worked for about 4 loads. When I connect the ohmeter to the terminals, the resistance slowly increases (which I understand is the capacitor building a charge from the ohmeter current). If I switch the ohmeter probes, the resistance still increases slowly but with a minus (-) sign in front.
    I'm out of ideas. Any light you can shed is greatly appreciated.
    Martin
    Hi Martin,
    Very Good checking everything, you pretty much covered all your bases.
    It sounds like your Capacitor may be bad, if you say you dis-charged it and switched the wires, then it started working again for at least 4 loads.
    Try taking the motor off(take pump off too), and laying it on the floor, but connected to the electrical, then turn it on in drain/spin and see if the motor starts.
    Jan 2008
    Flagstaff, AZ
    Thanks Jake.
    When I took the motor off, the shaft spins in agitate mode, but not in drain or spin (same as when its all put back together). After a minute or so of testing it wouldn't spin in agitate mode either. I monkeyed around a bit (discharged the capacitor, switched the wires, made sure the electrical harness was on tight) and I could get the motor to start again, but it would not consistently run in all modes.
    If I leave it on but the motor's not turning, I smell burning-motor-smell after a few minutes.
    Ok,
    It sounds like its possibly your motor, here's the one for your model:
    Manufacturer part#389248 is RepairClinic item#769
    If you purchase parts from our links here and you install them and it doesn't fix the problem, you have a 30 day full refund when you ship it back.
  1. whirlpool ultimate care 2 washer
    By mamapiglet1960 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 6th, 2007, 06:44 PM
  2. Whirlpool Ultimate Care II Filled, but will not spin.
    By JoshT in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 13th, 2007, 09:47 PM
  3. Whirlpool Gold 'Ultimate Care 2" water drains out too quickly?
    By booboo in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 19th, 2006, 12:45 AM
  4. Whirlpool Washer Runs but won't spin
    By Bus Driver in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 20th, 2006, 01:51 PM
  5. Whirlpool Ultimate Care II noisy during spin cycle
    By rdub79 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 11th, 2006, 12:23 AM
