February 16th, 2008, 04:28 PM
Whirlpool Gold Dryer drum will not turn.
It blows and heats and I can hear the motor running but the drum does not turn. Do these things have belts? I took the back off and could not see anything. What could be the problem?
February 16th, 2008, 05:36 PM
Dryer
- Do these things have belts?
Yes.
Access most likely from the front...model#?
http://www.applianceaid.com/model.html Some model# helps.
February 29th, 2008, 05:39 AM
OK finally got to finding the numbers.....
Mod: GEQ9858JQ0
Ser: MK2407399
TYPE: DWSR ELE-2406028-EH54
Any suggestions on a fix?
February 29th, 2008, 06:31 AM
OK so I figured out how to get the drum out and it is the belt. The belt does not have a number on it. ow do I know which one to order?
February 29th, 2008, 10:47 AM
Hi Gene,
Here's the parts diagram for your model, click here:
GEQ9858JQ0
then Select Diagram#1 then Diagram Location#39 is your belt you can order.
February 29th, 2008, 11:35 AM
Thanks Jake! I am curious about getting the belt back on without stretching or breaking it. Do I put the drum in first and then try to line the belt up as good as possible then putting it on the motor pulley last?
February 29th, 2008, 11:47 AM
Yes, the drum goes in first, then the belt. The belt comes with complete instructions.
March 8th, 2008, 09:23 AM
OK so I just realized as I went to put the belt on that the reason it broke is because the roller underneath the drum near the motor broke and must have cut the belt. The screws look like they came loose on the bracket on the bottom of the dryer. Is there a detailed diagram of how to put it back and where can I find the part number for a whole new bracket and roller?
March 9th, 2008, 12:48 AM
Here's the diagram that shows your belt#39 and your idler pulley#38:
The Idler pulley#38 is what you need correct? It has the roller that your belt loops on.
Manufacturer's Number: 691366
691366
By Jim_art in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: January 26th, 2008, 09:48 AM
By hiddenknoll in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: April 15th, 2007, 05:23 PM
By njwasher77 in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: June 28th, 2006, 11:43 PM
By Lincoln in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: October 13th, 2005, 11:14 PM
