April 17th, 2008, 01:47 PM
Whirl Ult.Care Washer leaves H20 in tub
Hello,
My old faithful Whirlpool Ultimate Care Heavy Duty Super Capacity Plus (model # LSR8233EQ1) has left a high level of water in the basket. It's making a sound like it is trying to pump out, and it seems to be going through (or trying at least) all the cycles. As you can imagine, it had a bit of a burning smell when I went to check on it. Any idea if this may be repairable...hate to give up on a good and faithful servant
Thank you very much,
April
April 17th, 2008, 08:44 PM
Its possibly something stuck in your water pump. I would check that first.
Also check your motor coupling, to make sure it didn't break.
Read #2 and #4 and #5 here on how to access these:
Here's the water pump for your model:
Manufacturer's Number: 3363394
3363394
Here's the motor coupling:
Manufacturer's Number: 285753A
285753A
April 18th, 2008, 05:51 PM
Cha-Ching!!
Hi Jake,
Thank you so much--you were dead on with the object in the water pump...it was a nickel causing the chaos! The couplers looked just fine, so my hubby put her back together again and she's been happily a washin' ever since!
Thank you very much...your help is greatly appreciated!
Best regards,
April
PS--that Cha-ching was a tip in your jar!
April 19th, 2008, 12:20 AM
Sounds good, glad you found the nickel in the water pump and got it removed.
Thanks for the tip.
July 30th, 2009, 05:10 AM
Hi Jake,
Hope you are well. I have a follow up question for you. This washer is completely rusted in the frame around the bleach mechainisim, etc and surrounding and is now falling apart and shaking badly when spinning, but the motor and pump (just replaced last week) is still in good working order. Is it possible at all to just replace the framework and keep it in operation?
April
July 30th, 2009, 09:36 AM
Hi April,
Is it the cabinet or top itself rusting or the washer base assembly?
Here's the washer base assembly for your model:
Manufacturer's Number: 285771
285771
Here's the top assembly that your bleach mechanism is mounted on:
Manufacturer part number 3949476 is RepairClinic item number 547270
3949476
By iowafarmer in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: March 8th, 2011, 08:05 PM
By cknh in forum Sears Kenmore
Last Post: February 18th, 2008, 10:30 PM
By lsparkie in forum GE/Hotpoint
Last Post: November 6th, 2007, 10:21 AM
By Adelescomp in forum Sears Kenmore
Last Post: May 21st, 2007, 11:34 AM
By Shawng1 in forum GE/Hotpoint
Last Post: February 5th, 2007, 07:54 PM
