September 7th, 2009, 08:34 AM
[FIXED] Whirlpool Ultimate Care 2 Dryer Won't Heat
Hi, sorry to bother you on a holiday, but our Whirlpool Ultimate Care 2 dryer won't heat. This is electric and the model number is:
LEQ9858PW1. I suspect a thermal fuse (no vent blockage), but have no idea where it is nor how to replace it. Thanks.
September 7th, 2009, 08:45 AM
Is it running and not heating? Or not running at all?
If its running and not heating then its possibly your thermal cut-off.
Unplug your dryer, pull it out from the wall, take the back panel off.
I would start by checking for continuity on your thermal cut-off. If you don't have an ohm meter take the wires off and jump it, use alligator clips OR electrical tape to tape them together, just for testing, DON'T RUN IT THAT WAY FOR A CYCLE IF IT WORKS!
Here is a photo of the back of your dryer without the back access panel on:
#1 is your thermal cut-off.
Part#279816
September 7th, 2009, 09:14 AM
Thanks, Jake I will start to dig into it!
September 7th, 2009, 09:28 AM
September 7th, 2009, 11:20 AM
Well, I checked out the thermal cut-off and there was continuity. I jumped the wires anyway and still no heat. The dryer does have power and no breakers tripped. What should I check next? Thanks
September 7th, 2009, 07:12 PM
Ohm the heating element#4 in the diagram above for continuity, take the wires off it first, make sure your dryer is unplugged.
Here's the heating element for your model in case you need to order it:
Manufacturer's Number: 279838
September 9th, 2009, 04:46 AM
Whirlpool heating element
Yep, the heating element was it, Jake. Thanks, but now my wife wants a whole new dryer. I am throwing some money into the Paypal pot anyway. Thanks for your quick and accurate responses.
September 9th, 2009, 07:33 AM
Ok, sounds good hametown, thanks.
May 24th, 2010, 09:56 AM
What is the next troubleshooting step for no heat?
I've checked both items for continuity. What is the next step?
May 24th, 2010, 02:34 PM
Originally Posted by
SolarCat
Is yours running but not heating, or not running at all? If the latter, ohm the thermal fuse for continuity.
September 21st, 2009, 10:21 AM
September 19th, 2009, 05:56 AM
September 10th, 2009, 06:38 PM
By tlw54582 in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: August 4th, 2009, 02:44 PM
Last Post: September 28th, 2008, 10:46 PM
By oldtoys1961 in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: November 28th, 2007, 10:54 PM
By johninohio in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: May 22nd, 2007, 09:39 AM
By JNader in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: October 26th, 2005, 05:32 PM
