Results 1 to 2 of 2
Thread: Not starting
    ttwntec is offline Member
    Jan 2011
    denver
    Default Not starting
    Model Number: lec7848d
    This dryer recently has been taking 2-3 times longer to dry. Tonight it has completely stopped working, I can hear the timmer clicking.
    Things I have checked..
    - Door switch - open and closed
    - Thermal fuse on the exhaust - 0 ohms
    - It looks like two Thermostat's on the heater, one next to the heating element and one above where it enters the dryer - 0 ohms
    - Push to start button = opening and closing
    My question..
    The cycling thermostat, located on the exhaust duct, has for terminals. Here is its picture from repiarclinic
    The two red wires show 0 ohms. The red wire shows 6.98K at room temp, the wiring diagram shows, if I am reading it right 5600-8400 ohm. It this suppose to trigger at a certain heat or as long as the reading is between everything its good?
    Yes, all those readings are fine.
    So the dryer will not turn on at all? Any hum sound like it trys to come on?
  1. Whirlpool Dryer Not Starting...Help
    By Gutter_Ball00 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 1st, 2010, 10:17 PM
  2. Whirlpool Duet Dryer Not Starting
    By Noiofnine in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 18th, 2010, 03:48 PM
  3. Whirlpool Quite Gold keeps starting over
    By jkohnman in forum Whirlpool
    Last Post: July 24th, 2007, 05:42 PM
  4. Replies: 7
    Last Post: September 25th, 2005, 09:53 PM
  5. Replies: 3
    Last Post: August 5th, 2005, 02:46 PM
