Results 1 to 2 of 2
Thread: my whirlpool dryer will heat up but not dry my clothes
    angel2211998 is offline Member
    Dec 2005
    fort campbell ky
    Default my whirlpool dryer will heat up but not dry my clothes
    my whirlpool dryer will heat up but will not dry my clothes. not sure why the heating element will turn red and it is also venting hot air if someone knows what the problem could be i sure would appreciate it if you could share it with me
    justme is offline Member
    Sep 2005
    Grand Juction, CO.
    Try the dryer with the vent hose off the dryer and run a load.. If the load of cloths dry in a reasonable amount of time then the problem is with the venting system going to the outside,,,if not then it could be a problem with the cycling thermostat or the back felt seal on the drum might be bad...
    good luck
  1. Dryer does not heat up to dry clothes
    By pango in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 6th, 2007, 05:06 AM
  2. Dryer burner wont stay on long enough to dry clothes
    By billyboy in forum GE/Hotpoint
    Last Post: October 5th, 2006, 10:13 PM
  3. Replies: 5
    Last Post: September 22nd, 2006, 09:48 PM
  4. Whirlpool gas dryer LGR7646ANO-no heat
    By JNader in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 26th, 2005, 06:32 PM
  5. Whirlpool Dryer gets Warm not Hot, Takes long to Dry
    Last Post: August 19th, 2005, 09:48 PM
