Results 1 to 10 of 17
Thread: Whirlpool Duet Washer drum knocking - plastic tub shredding
    wolverines is offline Premium Member
    Oct 2011
    NJ
    Default Whirlpool Duet Washer drum knocking - plastic tub shredding
    Model Number: GHW9400PW0
    Guys - just discovered this forum so before I end up trashing this washing machine, which has served us well for the past 6-7 years, I figured I'd check to see if there is a fix. I'm pretty handy and willing to try any suggestions.
    The washer has started knocking a bit lately and we've now noticed that the front of the metal drum (basket) appears to be rubbing on the inside of the plastic ''front tub''. This is causing the plastic to shred off (literally - almost like if you took a drill and drilled a hole in plastic where the edges shred or melt a bit). I peeled some of it off the other day but pieces of plastic are ending up in the washing machine. When I spin the metal drum slowly I can see that it's not going around in a perfect circle but instead something more elliptical and that is what is likely causing the plastic to shred.
    Only problem we've had with this washer is the F02 thing (well documented and when we clean out underneath all is good again). Would love to get this fixed, but also need to balance the repair cost with the ability to buy a new washer for $500-$700.
    Oct 2004
    Normally the kiss of death...
    Whirlpool Duet Washer drum knocking - plastic tub shredding-01090254.jpgWhirlpool Duet Washer drum knocking - plastic tub shredding-image0001.jpg
    ...the support strut at the bask of the wash basket may have broken or cracked
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Oct 2011
    NJ
    Quote Originally Posted by jeff1 View Post
ID:	2870Click image for larger version.
    Oh boy. That's not good at all. I hope that's not it but very well could be. I'll try to take a look at it tonight. Is there an easy way to get to the back of the wash basket to see if that's what it is? If that's it then it's time to order a new washer!! My wife is putting the pressure on big time to get this fixed or to get a new one! Thanks Jeff!
    Oct 2011
    NJ
    Jeff (or anyone else), it's not the drive pulley from what I can tell. I took the top and back off the washer and it looks fine. I don't see any cracks. The springs look fine, as do the shock absorbers (but I wouldn't know what exactly to look for). The plastic shredding I described is from the inner rim around the plastic tub, which is outside the metal inner tub. I've attached a few pictures below to hopefully help in the diagnosis. I'm going to run the machine again (with nothing in it) to see if I can see/hear anything (while I have the back and top off).
    Whirlpool Duet Washer drum knocking - plastic tub shredding-003.jpgWhirlpool Duet Washer drum knocking - plastic tub shredding-005.jpg
    Ok, you have a 10 year warranty on the outer tub assembly which includes the tub bearing, and lifetime warranty on the inner tub. Whirlpool pays for the parts, you pay labor.
    Here's your owners manual on your warranty:
    https://www.whirlpool.com/digitalass...08182276-W.pdf
    Its definitely the tub bearing thats bad and is causing those plastic shavings.
    Oct 2011
    NJ
    Thanks Jake. I cleaned off all the shavings and ran it last night and all it did is create more shavings. I'll go with your diagnosis as I know the pulley at the back isn't broken and the absorbers look ok (plus - that wouldn't account for the inner tub not spinning in a circle). I'm trying to schedule a repair now. It's a catch 22 because all of the repair shops charge a minimum service call fee ($100-$130 it seems). So as long as the parts are covered (and it doesn't take too long) it's worth it to repair it. Too bad you and Jeff aren't closer to me!
    Did you contact Whirlpool directly to schedule a service call?
    The 2 parts you will need would be about $500 and Whirlpool will pay that.
    Tub front:
    Manufacturer's Number: 285981
    285981
    Rear outer tub assembly:
    Manufacturer's Number: W10253866
    Oct 2011
    NJ
    Thanks Jake. I did contact Whirlpool and have set up a service call. I had one set up for tomorrow but I cancelled it because the service folks wouldn't answer what I thought were pretty reasonable questions. They charge $100 to come out and diagnose but they don't have a set hourly rate and said at that point they could give me an estimate of what the additional labor costs would be. So they could easily pull something like "it costs and additional $250 in labor to fix. We are here, what do you want us to do?" That doesn't work for me. I have another one set up for next week (AE Factory Service) as they are the other service provider for my area. They charge $130 to diagnose and repair. So assuming the parts are covered then I at least have an idea at what I'm looking at.
    Thanks again for the help!
    Yes, AE Factory Service(Owned by Sears) is the national Whirlpool service provider, They have good relations with Whirlpool. They are good to do this type of job. I worked for Sears/AE in the early 2000's after they bought AE from Montgomery Ward.
  1. Whirlpool Duet GHW9100LW washer drum is clunking
    By wegodeeper in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 10th, 2011, 09:29 AM
  2. Replies: 3
    Last Post: July 10th, 2010, 01:47 PM
  3. Replies: 3
    Last Post: June 29th, 2010, 03:19 PM
  4. Whirlpool Duet: Rattle behind drum
    By rstric in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 29th, 2008, 05:23 PM
  5. Duet Washer Leak under the drum
    By thedome in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 15th, 2008, 09:43 AM
