Results 1 to 4 of 4
Thread: Whirlpool dryer keeps a-whirling but won't stop a-whirling!
    wergp is offline Member
    Nov 2011
    Minneapolis, MN
    Red face Whirlpool dryer keeps a-whirling but won't stop a-whirling!
    Model Number: LGQ08611W1
    Our Whirlpool gas dryer (model # LGQ8611W1 -- 6 years old) won't stop running. It's a fire hazard.
    • Timed drying won't stop the dryer; and the dial won't move.
    • Accu-Dry (humidity sensor) won't stop the dryer, either; again, the dial won't move.
    • The dryer will stop when the dryer door is opened and will stay stopped even if that door is closed again.
    • Pushing the dryer start button will start the dryer again if the dryer door is closed.
    • The light inside the dryer will light.
    • The dryer vent was cleaned about 9 months ago.
    • There seems to be no other problems with the dryer.
    Sure would appreciate any thoughts on what is wrong with this dryer.
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Set your meter to read volts. Set the dryer on timed dry (you don't need to start it). Take a reading across the two black wires on the timer motor. If you read 120 VAC replace the timer:
    Timer 3406725 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2011
    Minneapolis, MN
    Default Thank you for your response.
    I tried with power to the unit and 120 VC did cross the two black wires. Thank you for your assistance.
    Jul 2006
    You're welcome.
  1. Whirlpool Dryer won't stop drying!
    By Caroline in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 8th, 2011, 06:15 PM
  2. Whirlpool Duet LG Cap Dryer wont stop
    By DavidM in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 19th, 2007, 11:36 AM
  3. Whirlpool Dryer Won't Stop
    By chainsawmd in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 3rd, 2007, 10:09 AM
  4. Whirlpool Dryer won't stop in autodry
    By Phil321 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: February 15th, 2007, 08:52 PM
  5. Whirlpool Dryer won't stop running
    By BrandiMA in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 18th, 2005, 04:59 PM
Tags for this Thread
