Results 1 to 6 of 6
Thread: Whirlpool Gas Dryer Timer Won't Advance in Auto Dry Mode, But Burners Go ON in Timed Mode
    mjj
    mjj is offline Member
    Jan 2012
    Wheaton, IL
    Default Whirlpool Gas Dryer Timer Won't Advance in Auto Dry Mode, But Burners Go ON in Timed Mode
    Model Number: LGN1000PQ0
    I have a Whirlpool gas dryer, model LGN1000PQ0. The timer won't advance in Auto Dry mode and the burner does not go on. But in Timed mode, the timer advances and the burner does go on. I checked the internal bias/cycling thermostat, high limit /205C thermostat, and the thermal cutoff (the thermostat-like device inline with the high limit thermostat) and all have continuity at room temperature. Is the issue my timer? Is there anything else I can check?
    Oct 2004
    Definetly check/ohm the heat contacts as per the wire diagram that comes with the unit.....no heat in auto and the timer will not advance, timed dry doesn't care and will still advance.
    If needed:
Size:  3.5 KB Dryer timer Manufacturer Number 3976584
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    mjj
    Jan 2012
    Wheaton, IL
    Thanks for the quick reply. Sorry, I'm not an electrician or tech. Wh
    t do the TM-WB, TM-OR, BK-BU-V, BK-BU, and BK-R refer to?
    mjj
    Jan 2012
    Wheaton, IL
    ah, newbie question -- those are the terminals on the timer itself! So TM-WB means measure continuity between TM and WB terminals? But what do I measure for BK-BU-V?
    Oct 2004
    Can you post a copy of your diagram? Couldn't get one this am to work for me.
    BU is blue, BK is black , R is red, etc.
    Example only:
    Whirlpool Gas Dryer Timer Won't Advance in Auto Dry Mode, But Burners Go ON in Timed Mode-inglisnewstyle-diagram.jpg
    BK to BU is motor.
    BK to R is heat
    JRAppliance
    mjj
    Jan 2012
    Wheaton, IL
    Whirlpool Gas Dryer Timer Won't Advance in Auto Dry Mode, But Burners Go ON in Timed Mode-lgn1000pq0-wiring-diagram.jpg
    This is the LGN1000PQ0 wiring diagram. Please explain how I should meaure the continuity on the timer pins, especially where it lists three pins (example: BK-BU-V).
    Also, my wife noted how, though the burner does go on with timed drying at first, it does not stay on, and the clothes just tumble without heat after a minute or so with the burner on. Is that still consistent with a timer issue, or is another part the issue?
  1. Replies: 4
    Last Post: November 13th, 2011, 04:17 AM
  2. Roper dryer timer will not advance in Auto
    By Hondro in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 9th, 2011, 11:15 AM
  3. Problem with auto dry mode
    By CNorris in forum GE/Hotpoint
    Last Post: April 11th, 2011, 11:56 AM
  4. FIXED: Kenmore dryer Auto-sensor mode
    By keving628 in forum Sears Kenmore
    Last Post: December 10th, 2009, 11:26 PM
  5. GE dryer fails to stop in auto mode
    By wddanie in forum GE/Hotpoint
    Last Post: November 29th, 2007, 05:14 PM
Tags for this Thread
