Results 1 to 4 of 4
Thread: Whirlpool ultimate care II Washer will not operate after fill and cannot select cycle manually
    cei955 is offline Premium Member
    Jan 2011
    Default Whirlpool ultimate care II Washer will not operate after fill and cannot select cycle manually
    Model Number: LSB6300PW3
    Washer fills ok based upon level selected, then sometimes starts washing and then stops during wash and sometimes during drain, rinse, or spin. If you try to select another cycle on timer to get it to run, 99 percent of time you cannot as it is dead. If it is in any cycle and you lift the lid and reclose it, it does not resume operating...it is dead.
    I replaced the timer and LID SWITCH to no avail, same thing. I manually bypassed lid switch, even though I hear audible click from lid switch, and get the same results. The diagram in washer says neutral terminates at motor from lid switch. Could I have bad motor??? Sometimes motor runs fine aggitating, spinning, etc. I can set auto sense to on or off and get the same results. Water temp works fine. Motor is very expensive and wash is building up quick.
    Oct 2004
    "Click" noise means nothing!
    LINK> Whirlpool Kenmore washer lid switch problem
    Kinda sounds more like the motor is shutting off on it's built in safety/thermal switch...after cooling down the switc hwill reset and the motor can run again but often cannot run right away after shutting off.
    Whirlpool  ultimate care II Washer will not operate after fill and cannot select cycle manually-drive-motor-661600-00632402.jpg Washing machine drive motor, 2 speed Manufacturer Number 661600
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Jan 2011
    Thats what I kinda thought, just did not wanted someone else to confer. Thank you Jeff for your quick reply.
    Ron
    Oct 2004
    Your welcome
    JRAppliance
  1. Whirlpool Ultimate Care II Washer - Bottom agitates, top does not
    By NovaKnowledgeNow in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 13th, 2012, 05:12 PM
  2. whirlpool ultimate care II washer problems
    By Donny Hunt in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 2nd, 2011, 01:33 PM
  3. Whirlpool Ultimate Care II stopped working mid cycle
    By edwards1687 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 20th, 2011, 09:11 AM
  4. whirlpool ultimate care 2 washer
    By mamapiglet1960 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 6th, 2007, 06:44 PM
  5. Whirlpool Ultimate Care II noisy during spin cycle
    By rdub79 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 11th, 2006, 12:23 AM
