Results 1 to 8 of 8
Thread: Dryer won't ignite
    rob77c is offline Member
    May 2012
    nj
    Cool Dryer won't ignite
    Model Number: LGR7646
    Age: More than 10 years
    Ignitor won't come on. Checked it with ohmeter and it registered 99 ohms. Removed the flame sensor. Registers .3ohms when cool. When warmed over a candle, it clicks in less than a minute, and the reading goes to 1. I jumped the flame sensor wires, and the ignotor still will not ignite. Any further suggestions appreciated. Thanks.
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    On a gas dryer the thermal fuse and high limit thermostat are in line with the gas valve. Use your ohmmeter to check both for continuity. The thermal fuse is located on the blower housing behind the back panel and the hi limit thermostat is on the heater box. If either one is open you should clean out the vent hose and vent and make sure you have good air flow coming out of the dryer. Check the fuse first. It's the most common part to fail.
    Thermal Fuse 3392519 Order now for same day shipping. 365 day return policy. RepairClinic.com
    High Limit Thermostat 3403140 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    May 2012
    nj
    Rick,
    Thanks for your quick reply. I tested the thermal fuse and there is no continuity. I have not tested the thermostat. To make sure its just the fuse, should I jump the wires and see if the ignitor comes on?
    Rob
    Jul 2006
    Yes, you can short the two wires on the thermal fuse together and the igniter will come on.
    May 2012
    nj
    Default All working!
    Rick,
    I installed the thermal fuse today and everything is working. Thanks very much for your very good help.
    Rob
    Jul 2006
    Good job Rob! Don't forget to clean out your vent and vent hose.
    ed1
    ed1 is offline Member
    Jul 2012
    NJ
    Quote Originally Posted by rickgburton View Post
    Since all is fine I would like to ask here,
    Besides a clogged vent are there anymore causes that would make the thermal fuse go bad?
    I searched the site and can not find any other causes.
    Would it be possible that just old age would pop the fuse or can there be something else?
    Thanks in advance.
    Jul 2006
    Like all parts, they can wear out over time.
  1. FIXED: 80 series dryer - glows but no ignite
    By SpartanDon in forum Sears Kenmore
    Last Post: November 11th, 2011, 09:27 AM
  2. duet gas dryer chattering again, igniter glows but flame won't ignite
    By bsikes in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 7th, 2011, 09:43 AM
  3. Gas Dryer doesn't always ignite
    By sickest16 in forum Amana
    Last Post: July 27th, 2011, 10:53 AM
  4. Whirlpool Dryer - Works OK then burner doesn't ignite
    By joe-security in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 10th, 2011, 02:52 PM
  5. Kenmore Gas Dryer 80 - glow but fail to ignite gas
    By yongoh in forum Sears Kenmore
    Last Post: July 17th, 2010, 08:24 PM
