July 3rd, 2012, 02:04 PM
Whirlpool Cabrio oil splatter and belt broken melted into plastic guard.
My washing machine was making a loud dry bearing sound on the spin cycle but then it stopped working. I tilted the machine over to look underneith and there was oil spatter everywhere and the belt was broke and burnded through the belt shield on one side. I know it has to be a bearing but my question is, how do you take it apart? I removed the top of the washer and removed the tub ring, impeller but how do you remove the basket assembly? Do i need some kind of a puller?
July 3rd, 2012, 04:44 PM
July 3rd, 2012, 05:55 PM
Yes, sounds like you have two issues, the tub bearing and the gearcase.
Outer tub assembly:
Manufacturer's Number: W10193886
Gearcase:
WHIRLPOOL W10324649 Gearcase, AP4560983 | AppliancePartsPros.com
You would have to go by the repair manual to replace these parts.
Here's the repair manuals for the Cabrio's models.
Cabrio washer with 6th sense:
www.applianceblog.com/manuals/Cabrio6th.pdf
Cabrio washer:
www.applianceblog.com/manuals/Cabrio_Washer.pdf
You can look over the manual for your model and see if its something you can do yourself, its a big job, but if you've done other repairs like this for other things, then you can most likely do it yourself.
By Texas_Ray in forum KitchenAid
Last Post: August 3rd, 2011, 01:51 PM
By billtriguy in forum Frigidaire/Electrolux
Last Post: October 3rd, 2010, 02:47 PM
By jboardman in forum Sears Kenmore
Last Post: November 21st, 2009, 03:17 PM
By diesel dummy in forum Ranges/Ovens
Last Post: December 26th, 2005, 04:11 PM
By Mark in forum Whirlpool/Roper/Estate
Last Post: July 9th, 2005, 01:24 PM
