August 20th, 2012, 07:50 PM
KitchenAid electric dryer doesn't start
I have a question about our 8 years old KitchenAid electric dryer that doesn’t start, model # KEHS02RMT1. This dryer has control lights on the front panel where we can select different heat levels or cycles so we can’t select anything and buttons are not responding. There are no flashing lights on the main control panel, not any type of error messages or beeping sounds. There is nothing turns on when we press any knobs. There is only light inside the dryer when we open the dryer door. We changed the main control board (P/N 8546219) to the new one and it still doesn’t work. Is there any way to check the control board? Is there anything else that we need to check?
August 20th, 2012, 09:59 PM
Yes, its your user interface button/buttons are shorted causing this issue.
Here's the user interface for your model you can order here:
Touchpad and Control Panel 8558455 Order now for same day shipping. 365 day return policy. RepairClinic.com
Here is the online repair manual for the Whirlpool Duet dryer(Your KitchenAid is the identical to this one):
http://www.applianceblog.com/manuals/Duetdry.pdf
Give it time to download.
Page 4-4 shows you how to remove the control panel touchpad assembly.
August 22nd, 2012, 06:39 PM
Hi Jake,
Thank you very much for your reply. I was able to remove the user interface panel, it was not easy)) I just ordered new panel. Thanks again I will let you know if this will resolve problem.
August 22nd, 2012, 09:17 PM
Ok, sounds good, yes keep us posted.
By mytoysrfp in forum Amana
Last Post: March 9th, 2012, 06:50 PM
By dave67889 in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: September 5th, 2011, 03:12 PM
By guy_fawkes in forum Amana
Last Post: March 25th, 2011, 12:43 PM
By tbedal in forum Whirlpool/Roper/Estate
Last Post: February 2nd, 2011, 07:18 PM
By roopooroo in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: April 25th, 2005, 06:44 PM
