Results 1 to 6 of 6
Thread: Gas Dryer not heating at all
    ecamar is offline Member
    Aug 2012
    United States
    Default Gas Dryer not heating at all
    Model Number: LGQ8000JQ2
    Hello,
    My gas dryer just stopped heating. I've checked the exhaust and it is clear. Lint is removed regularly. What do I check first?
    Thanks in advance for your help.
    Enrique
    Oct 2004
    Normally start with...is the hot surface ignitor coming on/glowing red as the place to start.
    LINK> Gas Dryer Troubleshooting | Appliance Aid
    If needed:
Size:  3.5 KB Igniter kit, will replace round or flat style, Manufacturer Number 279311
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Aug 2012
    United States
    I removed the igniter and ohm'd it. I get 53.7 when testing for continuity. The video mentioned the minimum should be 50. Is this my problem?
    Oct 2004
    Nope, that would be close enough.
    Does it glow red when calling for heat?....if no, check the thermal fuse...
    JRAppliance
    Aug 2012
    United States
    After thermal fuse replacement, flame and heat is present. Thank you!
    Oct 2004
    Make sure you check the filter, venting and vent hood....those are common reasons for the fuse to let go.
    Thankx for the updae.
    JRAppliance
  1. Dryer not heating, again
    By Tucq in forum Sears Kenmore
    Last Post: October 7th, 2011, 03:41 PM
  2. RCA dryer not heating
    By Tex Red in forum Dryers
    Last Post: March 30th, 2011, 10:49 AM
  3. Dryer isn't heating Up.
    By Chris20 in forum GE/Hotpoint
    Last Post: August 25th, 2010, 09:09 PM
  4. Dryer not heating
    By godolphins in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 29th, 2010, 09:41 PM
  5. Over heating dryer
    By bjohnson in forum Frigidaire/Electrolux
    Last Post: May 14th, 2007, 11:48 AM
