Results 1 to 4 of 4
Thread: Whirlpool Duet Gas Dryer won't turn on
    njwasher77 is offline Member
    Jun 2006
    New Jersey
    Default Whirlpool Duet Gas Dryer won't turn on
    I have a ~4yrs Whirlpool Duet gas dryer that suddenly refused to turn on. I ran the diagnostic test but no response. i then set it to the manual cycles and after a few minutes it lit up. However, the temperature setting keeps changing by itself. It responds to changes in the timer settings, more time or less time, for all the manual settings. But when i turn it off and turn it on again, its back to its zombie state... no displays. Any ideas on how to go about fixing this?
    Thanks guys!
    We would need the model# to help you on this.
    Sounds like you would need a new control panel assembly.
    Jun 2006
    New Jersey
    Whirlpool gas dryer (GGW9200LQ0).
    This is going to require the Repair manual if you plan to fix it yourself, as you want to make sure you order the correct part.
    It should be 1 of these parts that are failing.
    Here is the User interface .
    Here is the Electronic control assembly.
  1. Duet Gas Dryer: cannot turn off after auto cycle
    By PRK in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 22nd, 2007, 09:56 AM
  2. Duet Gas Dryer Won't Start
    By 92h22a in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 4th, 2007, 09:35 AM
  3. Whirlpool Duet Gas Supply Line
    By momus_98 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 5th, 2007, 09:58 AM
  4. Whirlpool Duet dryer
    By darrell in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 18th, 2006, 12:38 AM
  5. Whirlpool dryer won't turn off
    By Lincoln in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 13th, 2005, 11:14 PM
