September 29th, 2006, 05:01 PM
Roper (Whirlpool) RAX4232KQ0 Washer Won't Drain or Rinse
My Roper RAX4232KQ0, Type: 107, fills with water, goes through the wash portion of the cycle, and then gets to the rinse portion and stops. It won't drain or spin in any of the 4 cycles and the water has to be syphoned out. I can hear (and see) the timer moving along until about halfway through the rinse portion, then it also stops completely. Any idea what may be the problem and how to fix it?
Thanks.
September 30th, 2006, 05:10 AM
G'day,
Ckeck the lid switch and/or lid switch probe. If the lid switch fails and spinning and draining will quit but the filling and agitation will still work...
Lid switch assembly
Access helps...
September 30th, 2006, 09:46 AM
Yep, the assembly was broken where the screws attach the switch to the machine right under the lid. As you can probably tell, my mechanical aptitude is quite low!!! Thanks for the quick and easy diagnosis.
October 1st, 2006, 05:20 AM
Thankx for the update!...your welcome
By rickm in forum Whirlpool
Last Post: October 3rd, 2011, 04:14 PM
By Brittgee in forum Sears Kenmore
Last Post: July 26th, 2010, 08:05 PM
By Romen3 in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: November 5th, 2006, 12:09 AM
By limetwist in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: May 17th, 2006, 04:30 PM
By futurevip in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: March 12th, 2006, 01:08 PM
