Results 1 to 9 of 9
Thread: kitchen aid washer
    mike is offline Member
    Dec 2004
    Post kitchen aid washer
    ok the washer will not wash i have taken the washer apart and the coupling is ok the plastic thing with rubber thing with the motor out i can get it to work on spin but not on the wash cycle any ideas thanks mike
    Post imported post
    Hi Mike,
    Does the motor even humm in the wash cycle?
    If so, take off the pump, and then try it, something could be stuck in the pump.
    If no humming, check for voltage at the motor connector.
    Dec 2004
    Post imported post
    i have taken the motor out so its sitting on the floor i have taken the pump offi hear a humm like sound but sure where its comming from
    check for voltage at the motor connector how do i do this thanks for the help
    thanks for the reply
    Post imported post
    The way i do it is to take off the terminal block from the motor and there should be wiring diagram in the console of the machine to look at the wires coming from the power source of the 120v from the timer, when the timer is in the wash cycle.
    With the tub filled up to the small setting of the water level, that should activate the 120v from the water pressure switch to the motor terminal block.
    If you dont have a 120v reading, then you may have a bad timer.
    If you do have a 120v reading , it may be the motor out.
    Always check for broken or fraid wires thoughout the wire harness assembly, that would cause a lose of 120v as well.
    Dec 2004
    Post imported post
    thanks for the reply well after i filled it it worked on the wash. so i put every thing back together and its working.. is it possible to over fill the washer and for it to quit working. thanks for all the help mike
    Post imported post
    Hi Mike,
    I have seen if water or a obstruction gets in that pressure switch hose, it will not start agitating, then overflow.
    You would then disconnect the pressure switch hose from the pressure switch and blow through it to clear out the water or obstruction in the hose.
    Dec 2004
    Post imported post
    thanks for all the help i am gratefull for you help thanks again
    Post imported post
    Your Welcome Mike,
    Anytime.
    RHG
    RHG is offline Member
    Jan 2005
    Post imported post
    In order to get the case my washer I had to disconnect almost all the wires. How do you get it to run with the 110 volt plug and the timmer case removed? my washer hums but will not agitate. From this post it sounds like it could be either the pump or the coupler. How do you tell wich one?
    Bob
  1. Kitchen Aid Washer - Agitates But Doesn't Go into Spin or Rinse cycle
    By andyman1970 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: February 2nd, 2007, 11:50 PM
  2. Kitchen Aid
    By carwasher44 in forum Buy, Sell or Trade
    Last Post: December 30th, 2006, 12:23 AM
  3. Kitchen Aid Washer Leaks due to balance issues Repair ???
    By pauly in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 29th, 2006, 08:56 PM
  4. kitchen aid washer arm
    By gkormani in forum KitchenAid
    Last Post: September 29th, 2006, 11:23 AM
  5. Kitchen aid washer will not agitate
    By RHG in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 24th, 2005, 07:50 PM
