January 7th, 2012, 06:18 AM
Whirpool Calypso Washer problem..Please help!
Hello! I have a Whirpool Calypso washing machine that shows the SL code. It gets hung up in the rinse/spin and nothing I do has helped. I came on here and googled it and found they had updated the pump/motor assembly. I have bought and installed this new assembly but am still having the problem. Please help!
January 7th, 2012, 10:56 AM
Also need to check the sump in the rear of tub with flash light... (for objects blocking the check balls.. I have gotten in the habit now to check the sump every time I go for just the annual check up... you would not believe the amount of bra wires you can find in there..
So remove the pump assembly then I've used a small coat hanger with a small tip to fish out larger debris from that holding reservoir. Never know what you may find.
On the drain hose portion is a checkvalve built into the hose. Check it for restrictions or debris as well.
Post back and let us know what you find.
January 8th, 2012, 10:27 AM
Fixed it..finally!
Thank you for your help, Jake!! I took the hoses apart and found a bent paper clip blocking one hose. I put it back together but it still wouldn't work. I was excited at one part because I thought I found a rubber ball that was causing the problem but then smacked myself when I realized that was the check ball. HA ha. So last night I looked again and the lighting was just right to show an obstruction in the drain hose (the only hose I didn't take apart). This morning I took that last hose apart and I found an underwire to a bra just like you said! I can't thank you enough for your help and I'm glad I didn't just give up and buy a new washer! Hopefully this one will last a few more years! My husband and friends are even impressed that I fixed it myself. Thanks again..you rock!
January 8th, 2012, 03:46 PM
Excellent Cathy, good job.
By shootme200 in forum Whirlpool/KitchenAid/Roper
Last Post: October 10th, 2010, 04:55 PM
By cjboone in forum Whirlpool/KitchenAid/Roper
Last Post: May 4th, 2009, 09:58 AM
By lts_cards@yahoo.com in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: April 9th, 2007, 11:53 AM
By Packster in forum Whirlpool/KitchenAid/Roper
Last Post: March 11th, 2006, 02:35 PM
