Old February 16th, 2008, 03:28 PM
Gene3x is on a distinguished road
Default Whirlpool Gold Dryer drum will not turn.
It blows and heats and I can hear the motor running but the drum does not turn. Do these things have belts? I took the back off and could not see anything. What could be the problem?
Old February 16th, 2008, 04:36 PM
Dryer - Do these things have belts?
Yes.
Access most likely from the front...model#?
http://www.applianceaid.com/model.html Some model# helps.
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old February 29th, 2008, 04:39 AM
OK finally got to finding the numbers.....
Mod: GEQ9858JQ0
Ser: MK2407399
TYPE: DWSR ELE-2406028-EH54
Any suggestions on a fix?
Old February 29th, 2008, 05:31 AM
OK so I figured out how to get the drum out and it is the belt. The belt does not have a number on it. ow do I know which one to order?
Old February 29th, 2008, 09:47 AM
Hi Gene,
Here's the parts diagram for your model, click here:
GEQ9858JQ0
then Select Diagram#1 then Diagram Location#39 is your belt you can order.
Old February 29th, 2008, 10:35 AM
Thanks Jake! I am curious about getting the belt back on without stretching or breaking it. Do I put the drum in first and then try to line the belt up as good as possible then putting it on the motor pulley last?
Old February 29th, 2008, 10:47 AM
Yes, the drum goes in first, then the belt. The belt comes with complete instructions.
Old March 8th, 2008, 08:23 AM
OK so I just realized as I went to put the belt on that the reason it broke is because the roller underneath the drum near the motor broke and must have cut the belt. The screws look like they came loose on the bracket on the bottom of the dryer. Is there a detailed diagram of how to put it back and where can I find the part number for a whole new bracket and roller?
Old March 8th, 2008, 11:48 PM
Here's the diagram that shows your belt#39 and your idler pulley#38:
The Idler pulley#38 is what you need correct? It has the roller that your belt loops on.
Manufacturer's Number: 691366
icon
icon
icon691366
Maytag Dryer won't turn Jim_art Maytag/Magic Chef/Admiral/Jenn-Air 4 January 26th, 2008 08:48 AM
Whirlpool Gold Dryer wont stay on hiddenknoll Whirlpool/KitchenAid 1 April 15th, 2007 04:23 PM
Whirlpool Duet Gas Dryer won't turn on njwasher77 Whirlpool/KitchenAid 3 June 28th, 2006 10:43 PM
Whirlpool dryer won't turn off Lincoln Whirlpool/KitchenAid 1 October 13th, 2005 10:14 PM
