i have a KA khws01pmt1. while remodeling our laundry room we moved the washer. It hasnt worked since. i have replaced the pressure switch and the despenser motor and yesterday the main control unit. Now the washer works up until it is time to drain the tub and it just stops. i tried restarting and changing the cycle to the rinse / spin and drain / spin. Nothing. i ran the diagonistics this morning and it passes with flying colors. yes, it drains and spins. i have been working on this machine for over a month. Please help.
Greg Russell Olive Branch, Mississippi |
Hi Greg,
Thats very odd that it drains and spins fine in the diagnostics mode but not in any cycles. Did you replace the CCU thats located up in the top, this one: Manufacturer's Number: W10137702 Jake
Thats the one. 200 smokes. it is like it gets "hung" on the wash cycle. i am baffled.
Thats very strange that it just started doing all this after you moved it for your remodel.
Unless some wiring got disconnected or loose, I'm not sure why it would drain/spin in the diagnostics but in any cycles. You may have to bite the bullet and contact KitchenAid to come out and see whats going on. Jake
okay, i'm a little dense. when i run the diagnostics properly (letting it run thru on its on) the washer seems to hand on C5. it ran thru c1 - c4 pretty quickly and has been on c5 now for about 15 min. this seems to be the same way it acts in the wash mode.
finally quit after about 25 min. i did not catch an error code, so i restarted the dia. cycle.
went thru the dia cycle. stayed on c5 for 13 min, then completed the cycle w/o displaying error code.
the full timeline of events are: 1. we moved machine - unknowingly activated the "control lock" 2. even after reading your posts could not figure out how to unlock. went thru all of the ohm testing in repair manual. no reading on pressure switch. 3. replaced pressure switch. no reading on new switch. 4. stumbled on the unlock feature. 5. run cycle and gets stuck on despenser. machine would continually rotate the despenser motor and never select a position. 6. r&r the despenser motor and switch. still does same thing. 7. give up and call repair man. says "never has replaced" pressure switch. says ccu bad. wants $500 to r&r. i r&r ccu. 8. now current problem. cycles to "wash" indicator and then just sits there. one time all night. did i get a bad ccu? should it have given me an error code? is 13 - 20 minutes on c5 common? |
0kay. last update. i promise. thinking by running diagnostics i had some how taught the machine a lesson, i tried to run a load of clothes. normal cycle. cold/cold, high spin. begins filling, despensing, washing. now constantly turning clockwise (facing unit) at wash speed. no stopping. no changing directions. no rinse / spin. timer is counting down.
![]() i quit. i look forward to hearing from you. |
Where did you buy your CCU at? Please don't say ebay! If you do say ebay, then thats the problem.
Other than that I'll say this once more: You may have to bite the bullet and contact KitchenAid to come out and see whats going on, because I have no clue to whats going on, I've never seen this happen before. Jake
pulled top back off, unplugged everything and repluged. works fine.
| KitchenAid lost power during wash cycle | rickorachi | KitchenAid | 14 | July 9th, 2007 12:39 PM |
| Spin cycle not working on a KitchenAid washing machine | Aquafennatic | Whirlpool/KitchenAid | 4 | May 29th, 2007 11:34 AM |
| Kitchenaid Ensemble | Bendix_NY | Whirlpool/KitchenAid | 3 | May 24th, 2007 11:01 AM |
| Kitchenaid KUDS25SH Cancel / drain cycle | dmccarthy | KitchenAid | 3 | March 16th, 2006 08:04 PM |
| Cycle Does Not Finish | Jeff Bosch | Bosch | 1 | March 1st, 2006 07:10 PM |
