I have a Whirlpool Duet Ggw9200lw0 Gas Dryer. The unit is putting out no heat. I replaced the Thermal Fuse and the Thermistor and tested High Limit thermistat and the resistance between the pins on the Gas Valve. All were within published limits. I do not see the ignightor turning on at all so I tested the radiant sensor leads for continuity. I also put a volt meater on the leads to the radiant sensor and read a continous 78 volts. I have not pulled the glow coil by iteself. to test it for continuity.
I have been troubleshooting this for a week now. UUUUG. Any help would be greatly appriciated. |
Does the glow coil igniter glow red at all? Did you check the voltage to the glow coil igniter? Here's a good help link to check out: http://www.applianceaid.com/gas_dryer.html#noheat Jake
Thanks my friend, I think I am good to go
What did you find wrong?
| Heat goes out on my Whirlpool LGQ8000HQ0 gas dryer | oldtoys1961 | Whirlpool/KitchenAid | 3 | November 28th, 2007 10:54 PM |
| Whirlpool Duet Dryer Repair story -- stacked in a tight spot | curiojj | Appliance Stores & Service Complaints - East of the Mississippi | 0 | June 23rd, 2007 02:18 PM |
| Whirlpool Duet Dryer Repair story -- stacked in a tight spot | curiojj | Whirlpool/KitchenAid | 0 | June 23rd, 2007 02:18 PM |
| Whirlpool Duet Dryer - No heat | jwpetree | Whirlpool/KitchenAid | 3 | February 18th, 2007 09:26 AM |
| Whirlpool Duet dryer | darrell | Whirlpool/KitchenAid | 1 | May 17th, 2006 11:38 PM |
